Estimate on what RWHP will be
Old Jan 26, 2011 | 11:10 AM
mike mlodecki's Avatar
Default Estimate on what RWHP will be
On a stock 98 trans am with ARH LT's And a twin intercooled procharger D-1SC with 10psi? Other things will be added(heads,cam,etc etc.) but just as a base number with only the procharger and headers what do you guys think?
Thanks
Old Jan 26, 2011 | 11:11 AM
jdmotox333's Avatar
prolly around 500
Old Jan 26, 2011 | 11:00 PM
SnIpEz's Avatar
More than that. I wouldnt run 10 PSI on a stock internals LS1, it's a little too much for them, you're risking it at that. 8 PSI should be safe until you can upgrade to forged rods and pistons.
To give an example, buddys Camaro with a 3.5" twin intercooled P1SC made 520 rwhp with only 5.5-6lbs of boost, LTs, true duals, custom grind cam, (just remembered you'd be running stock cam so I may actually retract my first statement) and a few other small things, stock heads.
I wouldn't put on a supercharger without having a cam meant for boost first, but that's just me. I can't blame you for wanting that whistle though If it were at 10 PSI with stock cam, I would agree, probably around 500
Old Jan 26, 2011 | 11:06 PM
1FasstWS6's Avatar
I made 490whp at 5900 with 6psi on a D1 and just headers/exhaust. so on 10psi you will make well over 500 and possibly busted internals.
Old Jan 26, 2011 | 11:10 PM
WHPLASH's Avatar
A4/M6? LS1/LS6 intake? Only headers and 10psi, 460-470 rwhp. Add heads and cam, different story.
Old Jan 26, 2011 | 11:31 PM
nodrok's Avatar
450 rwhp
Old Jan 26, 2011 | 11:50 PM
JP's Avatar
JP
1000 rwhp
Old Jan 27, 2011 | 12:05 AM
blue00ZZleeper's Avatar
Don't listen to the "magic" number for boost pressure. As long as you don't get to greedy you'll be ok. It depends more so on the tune, steady fuel pressure and RPM. Don't spin the motor to the moon and it'll do ok. I have over 50K on the setup in my sig with no problems. I dd'd it for most of that time as well. She's well weathered and beat on lol 10psi with a good tune only spinning it to 6200 will be ok. Also remember that the 98's had weaker rod bolts.
Old Jan 27, 2011 | 12:54 AM
westtexasbuff's Avatar
This. I have a few friends that run 10psi on stock bottom ends.
As far as the power you should be around 500-550.
Old Jan 27, 2011 | 05:31 AM
Wait everybody to some posts, I am meaning only numbers with the procharger and headers, I am getting a forged motor, rods pistons, cam heads tranny 9"..all the works to make it right, I am jw what the power would be with only procharger and headers. But got some ideas that are around 500-550 so thats pretty good for me.
Old Jan 27, 2011 | 06:17 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
With a stock bottom end I would shoot for 8 psi of boost. With headers and exhaust you will be in the 500 to 550 rwhp range depending on the dyno you're on. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 27, 2011 | 10:26 AM
LS1RedZ's Avatar
Should hit 500 easily! What motor (ci?) are you going with? Heads cam?
Old Jan 27, 2011 | 11:26 AM
a forged ls1 347 from texas speed, along with FLT level 5 4L65E, 9" rear from brute speed, Im thinking 205cc heads from texas speed, cam not sure yet maybe torquer v.2 if that works well with the procharger.
Last trans am i had was a 2000 P1SC procharger with american racing headers and at 7psi it hit only 375-385 RWHP on a mustang dyno and i know that something was wrong with motor but didnt have anymore cash so it was good enough for me. but 500 and maybe over 600 with heads and cam? that would be awesome.
Old Jan 27, 2011 | 04:36 PM
BLAKE 01 WS6's Avatar
On 10psi it will be 500+ without a doubt. pretty much my setup except i have a small cam and mine made 562/508 corrected on a dynojet at 7.5psi.
Old Jan 27, 2011 | 10:58 PM
I'd say you should make right around 530ish through the auto. Is the forged motor in now or stock for now? A good set of heads, good cam and good exhaust will really wake it up.
Old Jan 27, 2011 | 11:15 PM
right now its all stock, bought the car bout month and a half ago. had a procharged 2000 ta sold it 3 months ago bought a hyundai, then bought another trans am ha. so stock now. procharger just came in today thats the first thing i ordered and now the rotating assembly is next with heads and cam being purchased at the same time.
Old Jan 27, 2011 | 11:16 PM
Phil99vette's Avatar
7 Second Club
If it makes 330rwhp NA, with 10# of boost(1.68 PR) under perfect conditions would net 558rwhp minus the hp it takes to turn the blower. Probably 510-535rwhp.
Old Jan 27, 2011 | 11:24 PM
Nice phil! Hows the new combo going?
Old Jan 28, 2011 | 08:36 PM
TWS's Avatar
TWS
My 2002 Z28 M6 would be a good reference point for you: Bone stock 11K mile motor. FLP long tubes+Y pipe, Magnaflow, BBK 80mm TB, 60# Siemens Deka injectors, Walbro GSS340. Tuned by Reckart.
Hitting 10# of boost: 546/506 through a Moser 12 bolt w/4.11's on a Dynapack. Dyno and tuning session in the Texas heat. 97* ambient temp in the shop that day. Don't want to get up and look for the IAT numbers. Very conservative tune due to bone stock motor. Wanted it to live rather than get an extra few horsepower. Could make a higher number if I dyno'd it right now in winter but don't care enough to do it.
