Turbo VS Procharger
I forgot one "How much of the work can you realisticly do yourself?" because you can go ahead and multiply the cost of all the parts used by 2 and thats going to be AROUND the cost of your project when its all said and done.
There is a lot more to this than just buying a cool engine and a turbo kit/supercharger if you want to go fast you gotta get the right transmission and rear end as well. Thats if you want to go fast and not break stuff fast.
My advice is keep reading and learn from others success and failures. You will spend less in the long run. Above all you will be able to have fun! Good luck!
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I am sitting back watching,reading,saving,planning and waiting.
Three things stick out to me:
1) 1970'-'80s cars with their leaf spring rear suspensions seem like they maybe the way to go as far as simplicity's sake.
2)5.3L LS engines keep looking better and better especially as FI engines.
3)I keep hearing about the new stuff blowing up so maybe the TH200-R4,TH350 or TH400 trannys are the way to go.
though.. i have noticed that one can find a lot of the basic suspension parts for the fox body stang for a very reasonable price which brings me to my next point..
Pros:
cheap and easy to find
easy to gut and you wont feel bad doing it
comes with the 8.8 rear which can be cheaply rebuilt
its been done on this site about 2397656832385652 times
full front end tubular k-member with a arms can be found for less than 5-600 bucks
other suspension parts can be found extremely cheap on mustang forums and are very common
lots of space under that hood
extremely light (compared to many other choices of vehicles)
end result is a built car done for a 'budget' that will flat out scare you with how fast it can go
Cons:
You will need to learn how to do the motor swap and wiring
You will be replacing a major amount of suspension things
You will not be allowed into a majority of the mustang "cool kids group"/local highschool kids
there are some others but im thinking you can get the idea
a 5.3 is a great idea for this build, look into the 76-78mm turbos for that build as well. All you would NEED to replace initially would be maybe some rod and head bolts along with an ls6 intake (on the motor itself). so this one gets my vote for cheap and easy .. just the way most of us like it.
t350 is light and can be built to be very strong but can get a little pricey
t400 is easy to have built to be strong but weighs a little more than the t350
4l80e will allow you to keep your overdrive but will be heavier than both of the first two because it has another gear in there.
I hope that I'm helping you here. Did you ever answer my initial questions? What are your goals?
With a D1-SC or a pair of old school TO3/TO4 GT-35's or Precision Turbo TA-5557's 480-620 RWHP shouldn't be hard even with only 334 CID(5.5L,3.83 bore & 3.622 stroke).
I would like to spend no more than $25-37K over a period of 3-6 years.
Last edited by N2OBaby; Feb 10, 2011 at 04:08 PM. Reason: Greater Clarification was desired.
Damn, I thought you made a new thread. My bad.
