What heads are good for a 390ci turbo motor
Old 02-08-2011, 10:06 AM
turbocamaro125's Avatar
Default What heads are good for a 390ci turbo motor
AES racing 390ci short block
Fast 102/102
91mm turbo
Epp blower cam
What heads should I get for my short block? I need something cheap $1400 bucks or cheaper....so I was looking at some Patriot heads (part number 2019)
specs on these heads are:
Combustion Chamber: 72cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.08"
Exhaust Valve: 1.60"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.090"
Retainer Material: Titanium
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 5-angle
Will these heads work good with my setup? Any info will be greatly appreciated...thanks
Old 02-08-2011, 10:15 AM
Restricted User
98Z28CobraKiller's Avatar
Is that a stock casting? If so, no good. If it's got a thick deck and flows well, it'll work. Your biggest problem at this point will be keeping the heads on at high boost levels.
Old 02-08-2011, 10:23 AM
yes they are new gm castings.what heads would you recommend with my setup?
Old 02-08-2011, 10:24 AM
afr's are out of my price range unless i could find some used ones...
Old 02-08-2011, 10:27 AM
Josh@KY-Turbo's Avatar
There are proven ways around the heads sealing other than 6 bolt blocks. Just gotta pay to have the work done.
Old 02-08-2011, 10:32 AM
so get the block o-ringed?.....and lets say I o-ring the block, are the specs of the heads good for my setup?
Old 02-08-2011, 10:48 AM
lt1773's Avatar
Eledrbrock 245cc ported by WCCH very good for high boost
Old 02-08-2011, 11:41 AM
Fireball's Avatar
You get all that nice stuff and want to skimp on the heads
Old 02-08-2011, 11:47 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
I feel like there is more and more of this stuff popping up here lately.
OP, Id suggest you save some loot and get a set of aftermarket heads.
Old 02-08-2011, 12:48 PM
87silverbullet's Avatar
^^^^This! Save your 1400 and save a little more and get you a set of aftermarket castings.
Old 02-08-2011, 12:57 PM
Well I got the Fast 102 and 102 throttle body for $600 so Id like to save some on the heads...lol but I understand where everyone is coming from, but this isnt junk thats getting thrown together but at the same time I dont make a **** ton of money either...
Old 02-08-2011, 12:59 PM
Edelbrock
AFR
Mast
or what do you guys recommend for heads?
Old 02-08-2011, 01:08 PM
7 Second Club
Phil99vette's Avatar
Fast 102/102
91mm turbo
Epp blower cam
Intake Valve: 2.08"
Valve Job: 5-angle
Like everyone else, why skimp on one of the most important parts. Get a good set of AFR,Mast,ET heads and be done with it. I did see a set of ET 245s for sale for 1700 in the last 2 weeks. I'd jump on those long before a set of patriots.
Old 02-08-2011, 01:26 PM
LS3RX7's Avatar
What he said!
Old 02-08-2011, 01:34 PM
I saw a set of AFR 225's for 1600 in the classifieds. Those would work well on there.
Old 02-08-2011, 02:24 PM
whitesscamaro's Avatar
I bought a pair of AFR 1630's for $1600 brand new last year.
Old 02-08-2011, 02:27 PM
7 Second Club
So you recommend a 5/8" thick deck for high boost applications?
Mast
AFR
Trickflow
All have 3/4" decks.
Old 02-08-2011, 02:30 PM
Ill have to look around some more to find some good deals on some heads...
Old 02-08-2011, 02:32 PM
this motor combo isnt gonna be a 1/4 mile drag car....its just for pleasure....highway...beat some 1 liter bikes....you know lol
Old 02-08-2011, 02:47 PM
Fondle's Avatar
i would just get some l92's and have them ported. stock castings work fine for people i know in my area. dudeman ran 18+ lbs of boost.. possibly 20+lbs.. not exactly sure, but i know he has gone over 18-19 on STOCK 317 heads, with ls3 gasket an EBAY head studs and isnt pushing any water
Quick Reply: What heads are good for a 390ci turbo motor
