Where can I get good boost line?(non rubber)
What do you guys recommend for good high pressure heat resistant boost line? Any links to any good sources? Right now im running crap rubber lines and im looking to replace it all for my current build.
I heard of people running some sort of nylon tubing. It seems very strong. Is the silicone tubing from RPS any good? The rubber stuff I used was starting to crack and I need something that is strong and will last a while and not have to worry about.
Phil do you have a part number on the actual tubing needed? And will this stuff work with normal pushlock fittings? Seems like the Nylon would be pushing it with the heat range.
