11:1 327 on E85 vs 370 on pump?
Down to the griddy, will a 327 with 10 to 11:1 compression on E85 produce around the same amount of power As a 370 on pump gas with 9:1? I like the 327 because the cylinder walls are much thicker,higher revving motor,cheaper,better gas mileage I would assume and just the fact that it will be a stock cube motor is cool and different.
I want to make right around 800rwhp with less then 20psi on AES ported 317's and later I would put some etp's or trickflows and bring the boost up to 26-30 psi and shoot for a 1000rwhp on E85
Suggestions??
I also beleive that the 327 would make about the same hp as the 370, but more importantly would make just as much tq. And if you ran a nice responsive turbo like a TC76 on the 327, it would have a amazingly flat power curve
