What Alternator Bracket is this?
Old Feb 20, 2011 | 02:13 AM
96TurboLSX's Avatar
Default What Alternator Bracket is this?
I need to get this setup on a 5.3 im boosting. Ive been looking all over for info on this setup but i dont see anything except pictures, no write ups. It looks like the stock low mount passenger side bracket on the ls1 out of camaro/firebirds that is just moved to the top of the motor? Plz help thanks!!
Old Feb 20, 2011 | 06:36 AM
MUSTANGBRKR02's Avatar
Looks like a modified stock f body bracket.
Old Feb 20, 2011 | 08:50 AM
Tally TransAm's Avatar
yup
i did a similar thing on mine
Old Feb 20, 2011 | 09:52 AM
JaYZeig's Avatar
Originally Posted by Tally TransAm
yup
hey tally...mind sharing what you had to do with this bracket? im also planning on "modifying" mine to work with my oem alternator on the pass. head as well..TIA
Old Feb 20, 2011 | 10:40 AM
tallreyes's Avatar
i have a spoolin performance alternator relocation bracket that utilizes the stock tensioner if anyone is interested ill do 80+ shipping its powder coated black i was going to use it on my car but with my ebay kit i cant use the tensioner because my driver side exhaust is to close to the block pm me if interested
Old Feb 20, 2011 | 01:34 PM
96TurboLSX's Avatar
Also interested Tally Ta...Plz share lol
Old Feb 20, 2011 | 01:54 PM
JaYZeig's Avatar
well i started to mount the bracket to the engine, and got a pretty good idea how it goes on judging from the pic posted from OP id like to see how the tensioner gets bolted on.
Old Feb 20, 2011 | 03:00 PM
96TurboLSX's Avatar
Plz no thread hijacking
Old Feb 20, 2011 | 03:44 PM
JaYZeig's Avatar
um, ok..since were all talking about he same thing here..ok guy
Old Feb 20, 2011 | 03:59 PM
The alternator serves as the tensioner as the old cars used to.
Old Feb 20, 2011 | 04:01 PM
96TurboLSX's Avatar
Sorry there was another post with pictures of that bracket the guy above us posted for sale, it has since been deleted. That is why i asked for no hijacking. A mod must have deleted it.
Old Feb 20, 2011 | 04:52 PM
JaYZeig's Avatar
ok then, my bad
looks like the alternator gets bolted to the bracket with just bolts and nuts on each ends...and the single bolt on the bottom in the middle bolts to the head, and you make some kind of adjuster to tighten the belt as needed. dont even have to cut/chop the stock bracket up.and you will need to make a spacer about an inch thick to go between the head and alternator bracket so you get the proper spacing.
Old Feb 20, 2011 | 05:07 PM
Bracket gets cut and you bolt it to the waterpump ear. Search Tally's name above for his pics.
Old Feb 20, 2011 | 05:28 PM
stock
modified
bolts to outside cylinder head bolt hole and used a slide type tensioner to the stock tensioner hole on the water pump
use adequate length spacers for belt alignment and remove necessary material from alt for cylinder head clearance
also need to mention i dont have a stock alternator. might need to modify the back cover of the stock alternator, not sure
Old Feb 20, 2011 | 08:07 PM
96TurboLSX's Avatar
Are the bolt holes on the front of ls1 cylinder heads, the same as 5.3 truck heads?
Old Feb 20, 2011 | 10:27 PM
Denali08's Avatar
No, I deleted the post myself since I noticed it is different bracket than the OP.
Old Feb 20, 2011 | 10:32 PM
Denali08's Avatar
stock
modified
What alternator are you using?
Do u have a pic for the tensioner installed?
