10:1 Compression?
Old Feb 20, 2011 | 12:46 PM
1evilss's Avatar
Default 10:1 Compression?
Hey guys im trying to figure out if im gonna be ok with a 10:1 CR on a 402 that gets 93 octane but may switch to e85 ......Also what kinda boost would I be able to run safely with 317 heads? Keep in mind this will be my street/weekend warrior....Car usually sees about 600 miles a summer
Old Feb 20, 2011 | 02:35 PM
TurboAv's Avatar
I say run it. E85 will allow more boost than 93 obviously. Stock heads can hold 15-20 psi with a good tune.
Old Feb 20, 2011 | 05:13 PM
1evilss's Avatar
So detonation wont be a problem?
Old Feb 20, 2011 | 05:26 PM
jay7199's Avatar
not with the proper tune.
Old Feb 20, 2011 | 05:29 PM
1evilss's Avatar
So my goal of 700rwhp is not unobtainable?
Old Feb 20, 2011 | 05:58 PM
TurboAv's Avatar
I don't know if you would get there on 93 without meth, but E85 would probably get you there.
Old Feb 20, 2011 | 06:30 PM
1evilss's Avatar
Ya e85 is sold less than a mile from my house so that's prob gonna be the fuel I run.....so with the e85 I should be fine with my build right?
Old Feb 20, 2011 | 08:08 PM
TurboAv's Avatar
I would run it. Talk it over with whoever is going to tune your car.
Old Feb 20, 2011 | 08:13 PM
Atomic's Avatar
I need a gauge for that
My 408 was 11:1 compression and I ran at 7lbs with 93 pump gas, no issues, just a **** ton of torque.
Old Feb 20, 2011 | 08:17 PM
1evilss's Avatar
What kinda power were u making?
Old Feb 20, 2011 | 10:38 PM
99mongooSS's Avatar
i would think you could reach 700 safely...we built a car where i work with 10.25:1 and 15psi, it made 790rwhp/760rwtq on 93. Now the big secret behind that car was the tune was dead nuts...it had a fast xfi which is sequential making us able to dial in each cylinder. so having said that i could see you safely making 650 to 700 with a stock computer safely with a little less boost.
Old Feb 20, 2011 | 11:10 PM
Atomic's Avatar
I never got the chance to take it to a dyno for other reasons, but based on track times it put down around 600hp. This was on a 6400lb truck with 35" 120lb tires, and a 14b axle, so I imagine it would have been closer to 675-700 on a m6 car.
Old Feb 22, 2011 | 12:16 PM
1evilss's Avatar
I also been thinking about selling the stroker kit I have and just running like a boosted 370....Is there a reason more people run those than 400+ cubes
Old Feb 22, 2011 | 04:42 PM
slowlsx's Avatar
thicker cylinder walls, small cubes will rev higher and turbo's love rpm.
Old Feb 24, 2011 | 12:38 AM
1evilss's Avatar
So do you guys think its better to run a 370 or go ahead and finish my 402 boost build
Old Feb 24, 2011 | 12:44 AM
Atomic's Avatar
a 370 and 408 have the same 4.030" bore...
Old Feb 24, 2011 | 07:47 AM
TurboAv's Avatar
I would run the stroker just for the better crank. Yes I know people have had stocker cranks over 1000, but I would be more comfortable with a good crank.
Old Feb 24, 2011 | 11:31 AM
Rickys S/C Z28's Avatar
i have a 10.2.1 347 made 650 with a stalled 4l80 on pump gas so 700 with the big cubes should be easy
Old Feb 24, 2011 | 11:39 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://www.exoticperformanceplus.com...Car.php?car=39
Check out this APS twin turbo build that we did back at the old shop that is no longer open. Your compression ratio will be just fine. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 24, 2011 | 06:17 PM
1evilss's Avatar
Thats what I like to hear guys....I was worried my compression would be to high to run a good amount of boost
