questions about C6 manifolds for LS1 turbo build
I bought a set of C6 LS2 exhaust manifolds off of Ebay to use one on my passenger side for the turbo plumbing. My first question is what do I plug these holes with (I am assuming it is for an O2 sensor or something)?
Secondly, where can I get a two bolt flange for this to weld to my plumbing? The spacing of the two bolts center-to-center is ~ 4 3/8".
Thanks!
Thanks!
so, just put a cut down bolt in that hole and call it a day. thats what i did. i cut it down because I couldnt find that bolt in the correct length.
I got custom made flanges from smi fab
http://smifabandcnc.com/gallery.php?...etteflange.jpg
they were like 40 bucks shipped for the pair, and he can make them with any size hole you want.
Why two passenger manifolds? I wondered if they would work turned upward in an fbody since they seem to be more compact, but I had doubts about clearance, especially with an SS hood. With the engine out of the car, it makes it even harder to gauge.
Looks like a sweet setup!
In my car the RH manifold flipped upsided down and pointing forward on the passenger side it was too close to my strut tower. I debated notching the tower but I didn't really like the idead of cutting metal out to make it fit. This worked much better for me. They are deffinetly a compact design.
