Pump gas 347/346 guys come inside
I feel you there man! I think we have found a mechanical problom with mine or at least we think wh have an idea. my car has had a slight "miss" in it and low and part throttle. we have been over the tune many many times so we will be pulling the heads of of it soon....hoping for a burnt valve.
347 at 18 psi made 950rw on the T56 for example, but the 427 at 16 psi made 1090 with the T56... at 20 psi through the TH400 now it makes 1030 rw. need to push it a little higher but about out of injector.
#36
current setup still working on tuning but at the moment is making 690hp
home built 346
callies crank
crower rods
mahle flat tops
9.1.0
224/224 .612 .609 116 114
afr 225s
pt76gts
14psi
meth injected
fast/nw 92 combo
t56
moser 12 bolt with 3.90s
shooting for 800 on 18psi
home built 346
callies crank
crower rods
mahle flat tops
9.1.0
afr 225s
pt76gts
14psi
meth injected
fast/nw 92 combo
t56
#37
well, the 427 made about 960rw on 12 lbs on the 6 speed, the bigger turbos didn't help much at low PR's. But as boost went up it can be seen
Nice!!!
I think its safe to say the car was close 1200rwhp with 20psi if you have T56?
