Boosted Cars are not very Quick!!!!
Old Feb 15, 2004 | 10:29 AM
sr71bb's Avatar
Default Boosted Cars are not very Quick!!!!
Guys, in terms of quarter mile performance it seems with the exception of maybe ONE car, boosted cars are getting their lunches handed to them by juiced cars and even NA cars. Why is that???
I see all these great dyno numbers but no really good 1/4 mile times. For example, you have 13 cars in the juiced list that have run high nines or better and only 1 notable BOOSTED example in the 8's and one more that BARELY broke into the nines. In fact there are two NA cars in the nines that I know about just here in Texas. If you compare DYNO numbers, some of the boosted cars have as much as 100-150 MORE HP but are slower at the strip where it counts.
The only theory I can come with is that the boosted cars are not producing power QUICK enough or the engine management systems are inadequate for boosted situations. I personally would really like to run a turbo setup but I will be dammned if I will do that and get my *** handed to me by a juiced or even NA car.
All input is welcomed!!!!
Old Feb 15, 2004 | 10:42 AM
mongse's Avatar
I ruin the end of films...
I completely agree with this. I've been saying the same thing for several years actually. I think it can still be chalked up to growing pains (poor ECM controls, head bolt design, belt slippage w/ the supercharged crowd). I'd just like to think that a 400+ci motor w/ a large turbo/blower should be able to crack a 9 pretty easily and a race motor w/ a race charger should be able to knock out a low 8.
Old Feb 15, 2004 | 10:48 AM
MIGHTYMOUSE's Avatar
easy answer, for every 10 boost cars there are 100 nitrous cars.. like comparing fast mustangs out there to fast f bodies. apples and oranges
on top of that most people go boost rout to retain driving manners IE street car not set up for exclusive drag racing.. simple enough?
Old Feb 15, 2004 | 10:56 AM
MYTURBOT/A's Avatar
Don`t make fun of us cause were slow. J/K...
I think there are alot of FI cars runing times that are inline with there power #s the big problem is traction. Most of the FI cars are only puting down around 500-600rwhp and runing 10-11sec 1/4mi times or mph is good but there 60ft and 1/4mi times suck becase they don`t have the suspension to hook at the track. FI is very expensive and to build a FI motor and suspension that is capable of low 10s or 9s is out of some of our budgets for now. Give it time and the FI cars will be running with the nitrous and N/A cars
Old Feb 15, 2004 | 10:57 AM
Birdie2000's Avatar
Another thing to look at is the race weights of these cars. Like MIGHTYMOUSE said, most people install blowers to retain street manners, and thus also tend to have much higher race weights because it's primarily a street car without things removed.
sr71bb's Avatar
Actually no MM, it is not simple enough. It's not like comparing apples to oranges, it's comparing track times to track times and they don't lie. I am having this EXACT same disagreement with my son who is juiced and I want to go turbo but realistically with what I have seen thus far, there's really no realistic way to run quicker than a juiced car that is set up properly. If I am missing something though I want to know about it, and that's the reason for this post. I think if we had a AEM contoller that would piggyback on to the stock PCM, we might see some better times. I am not flaming boosted cars because I would like to be one but NOT at the cost of running slower.
Good points regarding the weight issue. I know most if not all of the juiced 9's cars are less than full weight. I want to run FULL weight and low nines but even with 18-20 pounds of boost, high nines seem to be the best one could hope for at this time.
Old Feb 15, 2004 | 10:58 AM
CamaroSS_2002's Avatar
Also boosted cars are more fun to drive on the street. Also it takes ALOT more money to get a boosted car fully setup properly to run those kinds of times.
Lastly, Boosted cars have to "Build" Boost. A nitrous car has instant power and torque at the push of a button, you hit a 300 shot you have +300hp/tq at 2000rpm -- you can't do that with a boosted car.
Therefore a Nitrous car at the track will always remain the fastest on a consistant basis but how much fun is all that speed if you can't play with it on the street unless you have enough room to make a good run. With a boosted car you can drive around just giving a little gas to feel the power and not drive like a maniac.
I am going for the STS turbo kit cause it'll work great on the street and I get to enjoy the turbo. I might bring procharger back on the table if their new 8-rib system works out, even then I still don't like the idea of changing belts every 8-10k miles or less.
Old Feb 15, 2004 | 11:02 AM
MYTURBOT/A's Avatar
[QUOTE=sr71bb] there's really no realistic way to run quicker than a juiced car that is set up properly. QUOTE]
Then why don`t you go line up with Harlan,rob raymer, Prostock, or Mighty mouse.
Old Feb 15, 2004 | 11:04 AM
we HAVE aftermarket controllers available to us.. $$$
the more people there are running boost the more percent of them will have the $$ to fund what it takes to support a boost car.. then that percentage has to have a percentage that actually drag races and after that they have to WANT to make a race car out of their car..
i still think i am absolutely correct.. if you dont want opinions then dont ask.. you seem to have your mind made up.
track times are hp, weight, and traction.. we are behind on the second two.. there is theres just no way to make a stripped FI car weigh the same as a stripped nitrous car.. just more stuff...but the season is just about to start
Old Feb 15, 2004 | 11:05 AM
thanks myturbo, gotta print that one !
p.s. my timre in sig were with about 500 avg hp through the gears. not the new set up. which avg's about 740
Old Feb 15, 2004 | 11:17 AM
sr71bb's Avatar
MM, I DON'T have my mind up. I WANT to run a turbo but I don't want throw a bunch of money at it and find out there's no way to be quicker than a juiced car in the quarter. You guys are the ones that are pioneers in this boosted area.
I sincerely want to know what it might take to make this happen because it hasn't happened yet. I guess what I am asking is what do you guys see as the boosted limitations and how and IF they can be overcome in regards to a car being quarter mile quick.
So a recipe please, for a low nine second boosted car that weights 3700 pounds with me in it that I can drive every day. DO we have the technology or not????
Old Feb 15, 2004 | 11:34 AM
MYTURBOT/A's Avatar
Sure if you have the $30000 to do it and the car. A 427ci FI motor 8.5:1comp. with the turbo tech race kit and a T88 turbo 16psi. Fast or gen7 engine management. Th400 trans, 9in rearend and a huge fuel system with a sumped tank to support it. With that you should be seeing 8sec. 1/4mi times. Won`t get much for gas milage but Man would this setup be fun.
Old Feb 15, 2004 | 11:37 AM
sr71bb's Avatar
[QUOTE=MYTURBOT/A]
I respect what those guys have done with boosted motors but they would be no match quite frankly with my son's car. I am trying to build a boosted setup that would compete with him myself and that's the point of this post to find out how and IF it can be done
Old Feb 15, 2004 | 11:43 AM
sr71bb's Avatar
Technically, a C5R block IMO is not an LS1 anymore if that's what you are referring to. Yeah C5r block and C5R heads and BOOST probably WOULD do it and HAS done it. That's basically what 1BADLS1 is now @ 8.62 in the quarter on 19pSI ATI F1 supercharger.
Old Feb 15, 2004 | 11:51 AM
MYTURBOT/A's Avatar
I was thinking 6.0 iron block or even a ls6, would be sufficent with a set of stg3 ls6 heads. Have the heads and block O-ringed and you won`t have any problems lifting heads. with a good tune and some excellent driving 8s are no problem for an aluminum motor IMO. Rob is making 750 with a stock motor which should be enough for 9s with a good launch and run. With a bone stock motor!
Old Feb 15, 2004 | 12:02 PM
MYTURBOT/A's Avatar
[QUOTE=sr71bb]I respect what those guys have done with boosted motors but they would be no match quite frankly with my son's car.
What are his times? He would have to be running a Head cam motor with about a 500shot on it which is not the norm for a nitrous car.
Theres always somone out there faster then you are you can`t win them all. just like i will never be running in the same class as the guys i just mentioned above. Every power adder has it`s top dogs that most of us will never beat but still try .
Old Feb 15, 2004 | 12:10 PM
SidewaysTA's Avatar
Yeah, what does your son have and what does he run in the 1/4?
Mike
Old Feb 15, 2004 | 12:35 PM
z98's Avatar
z98
Trap speed equals power.
I see all the FI guys making great numbers there.
That tells me their cars aren't as well set up for the 1/4 as the n/a / nitrous guys.
So look at what your son's car traps, look at what some of the boosted guys trap, find a setup that traps higher, then build a ligher car than your son with more tire and you should be there.
Old Feb 15, 2004 | 12:42 PM
sr71bb's Avatar
[QUOTE=MYTURBOT/A]
Why do you assume this???? Juiced cars with much less HP are out running boosted cars, that's the point of this post. NA 550RWHP LS1 ran a 9.69 (Yes I was there). We have a NA corvette down here that is running mid tens and several fbodies that are. ALL of these have considerably less HP than some of the boosted cars. BTW my son's car is running much less than that 500HP you threw out there but I am not going to talk about his setup because he has asked me not to. It will be public knowledge soon enough however!!! LOL.
Z98 --- Great Point!!!!
