Where else can I get oil for turbo feed?
Do what we did, we ran a -4 line from that spot over the filter to a block that has two 1/4" NPT fittings on it. One for the gauge, and one with a -4 adapter for the turbo. I have to look to see if I have any pics.
Sean
Sean
I could poss run a T but this sending unit from Autometer is huge and personally I don't like using T fittings for fluid flow....especially for turbo oil. But If I can keep the sending unit low and outta sight and get oil from back of block then I'll be golden
Check out Modular Turbo's LS1 oil distribution block. It replaces the plug setup by the filter, with 2 outlets.
http://modularturbo.com/storefront/p...products_id/39
Restricted User
You can run your oil feed from the hole down by the filter then just buy the adapter to stick in the hole up top to put in the oil sender. Our experience has been that the electronic oil senders don't like the heat down there by the filter. Specially if the DP will be running out that side.
I use this hole for my oil pressure gauge and tee in -4 to my supercharger. Well at least I did with my old LS6 block
Just get an M20x1.5 to -4 adaptor.
For current LS2 block I just drilled and tapped the valley cover to accept a fitting to use the same oil supply.
Although the red hose has now been replaced by Earls ProLite
If it isnt listed on their website, just phone them
