Most power LS1 can handle?
10.1 at only 500HP is WOW. As for me, I'm sceptical about our so-called-tracks preparation and my suspension skills (which are 0). So I thought 900whp would still let me run 9.5 even in those conditions. As I said, we had 8.5s big-block car on our track and it could only do 6.5s in 1/8 due to traction issues
And for the most part all that happens the more power you make....you just spin the wheels further up the track.
My fastest times on any of the poor surfaces were with a 5.7 and relatively mildly tuned.
Any of my bigger engines just resulted in worse 60fts and worse times. Although with slightly higher trap speeds.
Obviously using an automatic will be a big help, and if you can fit massive tyres, that will be a big help too.
But you are still asking for a lot. You need traction to achieve your times. Not as much power as possible.
Has anyone tried to add extra head bolts/studs to 4 bolt head? Read it in A. Bell book, that adding just small 5/16" bolts help BBC heads clamp tremendously. Makes sense to me. Now I wonder is that possible with our heads? Looks to me there is some meat on the sides of cylinders where extra holes could be drilled...
And with regards tyres. Ive never used those tyres before. But on a normal tarmac type airfield Ive tried MT DR's, MT ET Streets and Hoosier drag radials. All 255/50x16 or equivalent size.
The ET streets were the by far worst, and the Hoosiers the best. Roughly 0.1-0.2 sec difference in the 60ft with each tyre.
But all still over 2secs on that surface ! And still leaving black lines all way through 3rd gear.
An easier option would likely just be to upgrade to 1/2" studs, although the 11mm ones do work well.
Or go to a ringed setup like Andreas used, although not sure how easy that is on an alloy block
Yepp welding is out of question cause heads and block will become "soft" without special heat treatment. I'm looking for budget solutions
So yes, in THIS particular thread I'm worrying about power. I might have created wrong impression that we race on dirt here, that's not true
between RWD cars, most powerful still run the fastest. And then go standing mile and kilometer events. So yes, here I want to know how to make my combo run the most power. 1200-1300HP probably, whatever LS1 can take
P.S. remember, I can always turn down boost if needed
But over the 1/4, there are 4wd cars with 4-500bhp that run faster than me on an airfield. I simply cannot get traction over such a short distance.
Over a mile, it's a rather different story.
Although even last year when I raced over 1km at Edinburgh airport at a charity event. Many cars were still crossing the line first, or very little difference. Although even the fastest of them was still 25mph down on my trap speed of around 180mph.
I simply couldnt get any grip until well into 4th gear.
