Most power LS1 can handle?
I have forged LS1 (2004' block) - Eagle crank, Eagle H-beam rods, Probe Industries pistons, ARP head bolts, Patriot Stage 2 heads, 9.2:1 compression. What can I squeeze out of this motor? Preferably do it reliably
I'm going to switch to E85 for safety and cooler combustion too. I'm talking about good tune, and moderate build quality.
I guess I should have called thread "How many 900whp+ LS1's are out there"
What would be weakest part in my setup - block, or lifting heads?
Really there are far too many variables to make a statement like this. The internal components are what will dictate a limit. I mean look at it like this: If you are going to spend $XX,XXX on superior internals, heads, and intake are you really gonna put that in a stock LS1 block?
I think heads lifting or cylinder walls splitting would be the main areas of failer to watch.
The studd would be a little stronger 190000psi vs 170000psi arp bolt but the head will likely flex befor you streach the bolt. The stud at the same tq will clamp the head tighter due to the fine thread vs corse.
I have ARP bolts now, are studs any better?
Sorry if it was too long, but your answers were technical and useful so I tried to give the most info too
So I can't understand what's going on with heads on LS1, each head only handles half the power, so why can't LS1 run 1000-1200whp? Slightly longer distance between studs perhaps?
To run more boost reliably you need either an aftermarket head with a thicker deck, or the LSX block that has 6 bolts per bore (Which will require aftermarket 6 bolt heads).
And yes, the studs are quite a lot better than the bolts.
Since you went with a built 4L80 you need not worry as much about breaking a tranny. I'd step up to a larger turbo that will not choke on the exhaust side. Like an S80 or S85
. To run more boost reliably you need either an aftermarket head with a thicker deck, or the LSX block that has 6 bolts per bore (Which will require aftermarket 6 bolt heads).
.Yes I keep in mind slightly larger turbo, that would help the heads stay too I think.
Lastls1, recently someone posted dyno with 1140whp LS1
So 800whp seems too underrated
