LS9 cam in a turbo 5.3?
How well would this cam work? Keep in mind this is not going to be a track car or a dyno queen. Im most likely going to have a 70 or 76mm front mount, 241s w/ slight portwork, truck manifold setup. Im looking for fast spool up and something I dont need to rev super high. The one concern I have is the -24.5* of overlap, but LPE is now recommending this over their GT7 cam for turbo/SC apps. Thoughts?
That cam is made for a square port head...That alone is enough reason not to run it. The cathedral port 241's will want a completely different cam profile..not to mention the displacement difference.
LS6, LS7, LS9 would all be better than a stock 5.3L cam. None of them would be near as good as one custom speced for your exact rig. The cam is a fairly important part of the overall equation. Why not have Pat G or someone you trust spec one that's optimum? The 220/220 .581 114 or 115lsa that shows up in the for sale section quite often would be one that would work well and be cheap if you're on a tight budget.
too much ex duration and not enough intake duration and too much -overlap
depending on your turbo, and with cathedral style heads, your typical turbo cam would have either equal or a little more intake duration as exhaust with a lsa of about 116-118 but if you have a large turbo for you setup it does not hurt to have a little more exhaust duration then intake and lower lsa
the ls9 was designed for supercharged app with square port heads that flow much better, definitely not the best choice
Whilst I have never tried it, I'd find that hard to believe.
Almost any mild cam will always work very very well on a turbo build. That's why virtually ever OEM turbo cam is like that.
People have made very good power on even a totally stock camshaft.
