Did I make the wrong choice going with an LS6 cam?
I did a head swap last year and already have dual valve springs on the heads, so the only thing I'm going to change over right now is the cam.
After the cam the plan is to procharge the thing... but I'm starting to think I am leaving a lot of power on the table by not going with a bigger cam.
At the same time I'm supercharging a stock shortblock with 90k on it...
Should I sell the LS6 cam and go with something else? If so, what?
Or should I stick with the LS6 cam supercharge the car and build a new block that can handle more power before I throw a bigger cam in?
Power? 500whp is where I want to be, but I'd rather make less and have the engine hold together then more and risk it.
My budget is 5 grand, give or take.
You did good !Don't second guess yourself on this
a LS6 cam has something like a 118lsa id have to do the math but i dont think there is any overlap in that cam Heres 3 that i found from a search that took me 1 minute Tom!
Ls6 Cam specs 204/218@.50 .550/.550 lift 117.5 LSA
LS6 Cam specs 207/217 @.50 .525/.525 lift 116 LSA
Hot Cam specs 219/228@.50 .525/.525 lift 112 LSA
Now that he's got me worked up about it LOL
I know one of these LS6 cams is a good cam for a FI stock engine but cant remember its been so long ? Im pretty sure its the smaller lobed cam that will take the stock LS6 springs and something to do with the exhaust overlap too from what i can remember ?? I was going to use one along time ago till i just decided to build a forged engine and just bought a turbo cam for my build .Now that im thinking about it im pretty sure it had to do with the lift of the cam and not having to remove the head for the daul spring install. Im pretty sure it was 02 ZO6 cam that FI guys were using that did bleed off some boost in the higher RPM s and it just needed a LS6 spring upgrade for the stock LS1 heads, but if this guy all ready has the head done, he really doesn't need to go this route if he doesn't want to.But i know its a decent cam for a stock LS1 engine from what i can remember and from what alot of guys on here have said about it. Can he ((GET))a better cam? Sure, But is his cam garbage?Absolutely not if its the right LS6 cam. **** YOU TOM LOL Making me type all this **** with my 1 pecking finger lol
UnderBoss
Garage is empty, add now
Trader Rating: 1
Default F/I Cam experts-Stick with LS6 cam or 224/230, 114 lsa for 346 forged LS6 D1Sc motor
Have a lead on picking up a decent blower cam COMP 224/230, 581/591 lift, 114 lsa, for a stock cubed forged LS6 blower motor I am planning to build for my ECS D1SC Procharger setup that will see between 10 and 12 lbs of boost.
If your a f/i cam expert you already know that a stock 02+ LS6 cam makes great power on and off boost and makes for an excellent cent. supercharger stock cubed blower cam.
I LOVE the low end torque that the stock LS6 cam makes off the boost for normal driving and of course it makes big power on boost; howerver, i prefer an aftermarket cam if its going to make sig. more power without the car feeling like a dog off boost. and don't mind the extra hot rod sound of the aftermarket cam.
QUESTION THEREFORE is: Do I just keep running my stock LS6 cam for the new forged LS6 blower motor or will the 224/230 cam, 114 lsa, 581/591 lift cam make sig. more power off boost and still not feel sluggish down low (off boost).
Question number 2: Will the stock LS6 cam make more torque down low off the boost stop light to stop light for normal driving vs. the aformentioned blower cam.
Question number 3: Is there another cam you recommend that will fit my goals for this motor which is max power on top on boost and not losing anything down low vs stock LS6 cam (off boost).
Thank you for informative reply!
__________________
2006 Black/Black C6 Z06, black wheels, Killer Bee/Beehive CAI, B&B Bullet Mufflers and of course 427 Badges; 1969 Plymouth Road Runner, 440cid, Ralleye Green Hardtop with black steel wheels, and black fiberglass 6-pack lift off hood, soon to be MUCH faster!
Other than that it's an awesome cheap boost cam
http://www.empirenet.com/pkelley2/Overlap.html
or sell it to me and I'll use it for my turbo lsx fox build..
