Critique: My radiator/condensor/puller fan setup
I took some pics to show depth. I know that the stock fans protrude further off center, but I measured more from the center as that is where the turbo is going to be positioned anyway.
If I cut the shroud in these areas from the inlet and outlet it should sit nice and flush against the rad.
Ground shots
Griffen rad and flx420
Stock rad and puller fans
Stood up shots with condenser
Griffen, flx420, and condenser. Approx 5 3/4 inches (Note that this isn't firmly sandwiched together. May save an extra 1/2 inch.)
Stock rad, condenser, pullers(approx 7 1/2 inches)
I think I'm saving a good couple inches with this setup and adding that with a stood up radiator I should have some good room up front for everything to clear. Is there anything I should be concerned about before cutting the fans and mounting everything together? Also, since the block isn't in yet is it best to get the rad setup mounted then drop in the engine. I'm pretty sure that is a yes, but curious to hear otherwise.
It seems like no one really does pullers on here. Most go with pushers, but then again my setup is to retain AC and I was hoping to mount my trans coolers on the front of the condensor like I currently have. There has got to be someone that has pullers around here.
Not sure how this will work but im running out of options.
I really like your setup, do you know what cfm those fans pull? I like that its a shrouded puller, those usually work alot better.
before swaintech coating
