Bye-bye bottle. Hello twins. LS Coupe refit.
#123
Let me get some new tires back on it and make some full pulls. I want it to be all it can be before I bore you guys with assumptions. But I will tell ya this, I already beat the old dyno record and I just got started.
#124
I was having some issues with the Holley DIS coils... Well here is my fix. Eliminate the need for them. I should have this setup on my motor by next week. Going with a MSD box (Digital 7 Plus with a HVC II coil)
FYI, I could not mount the Jesel distributor forward because of clearance issues with the turbo. So I made this bracket to rotate the head 180 degrees. All the plug wire clear the valley plate and there are spacers behind the mounting bracket to simulate the Jesel belt drive cam cover... Everything will make more sense when you see everything mounted on the engine with everything in place.
#128
No dyno numbers, but I did take it to the track today.
It will not build any boost at the line. Converter WAY to tight. Hell, it won't fall out of a freakin' tree for the first couple hunderd feet. My 60' times were in the 1.8's!!!! BUT... When the boost does kick in, WOW!!! With about 7 lbs of boost, it ran 161MPH!!! on a 10.10 second pass!!!...
#129
7 Second Club
Is the A/F 12.5-13.0 during spool up?
Have you bumped the timing during spool up to 36-40 degrees?
Have you advanced the cam 4-6 degrees?
Will the car go to 3300 rpms on the transbrake?
Do you have a 1.32 housing on the turbo?
What tranny fluid do you have in it?
#130
Hey Phil,
Here is what I have.
14.0 A/F during spool
Timing fixed @ 32. Pull timing during boost (No boost at the line)
It is advanced 4 degrees now
No. It will not even go to 3000 RPM on foot or trans brake
Yes. 1.32 housing
Redline
Yes. 1.32 housing
Redline
#132
No problem on the cam advance.
And I'm using the Holley Dominator EFI for the fuel, and a MSD 7535 Digital 7 box and a Jesel belt drive distribitor for the spark.
Converter is a Neal Chance bolt togerter 10" with a stage 3 stator. I have a stag 4 stator I can throw at it too... Which I think I will.
#133
7 Second Club
I thought "lean and mean" was what you wanted when trying to build boost off the line... But I can pull it down if you think it would help.
#134
That is the exact same converter I had. Started the same way as you. Stage 3 full tight. I can tell you that your combo(427" right?) will spool that converter no question. That is the same converter I sold to Andreas because I needed a tighter converter than the 10"/stage 3 combo on the 438".
#135
7 Second Club
I would try those changes 1st. If they dont work, I would loosen it 2 shims, that will gain you 200 rpms. I think the air/fuel will gain alittle, advancing the cam alittle, more timing will gain alittle, add all those little changes will get you to 3200-3300 and the turbo will light off. At the end of the day I bet you will be in the stage 3 stator with 2 shims loose.
#136
#137
Here is some in car videos. No full passes because it was breaking up at high(er) RPM and boost. You really can't hear it in the video, but when I lift off the gas, that's when it starts to break up. I even tried getting back into it a few times but it would always break up again.
It stalls better now, (thanks, Phil) but still no boost on the brake. But I think I'll get there now with a little more timing and employ the 2 and 3 step. I had the steps it set at 4K but it never hit it either one. But I did not want to mess with that this outing because of the engine miss.
As for the engine miss. I pretty much nailed it down to spark plug gap. It was building more boost than I thought and I had the plugs gapped at .030/.032... And I think it was blowing them out. I was no where near my 8500 RPM shift point but the boost was up around 25 PSI on a few passes and that's when it would start missing. I'm also going to up my spring pressure a little too... That could have been a contributing factor so I'm going to put another 50 lbs on the seat. Plugs will be gapped at .020"
As I said about, I'm going to start putting more timing in it at the time and more total timing too. Plugs looked fine but there were no timing marks on the strap. At the line, I was at 35* until it stated pulling it fast after 3 lbs of boost. Total timing at Max boost was 10* <That's pretty low so I'm sure putting some timing there will help things too... Wish me luck.
PS: It's freakin' hot here now (Arizona) so I won't be testing this thing again until the Fall. I "might" take it to the LSX Fest in Kentucky but that will depend on if I can spare the time to go...
http://www.youtube.com/watch?v=tv8a8...ature=youtu.be
#138
7 Second Club
With an MSD8 plus box, I gapped my plugs at .018 sometimes .016
What was the A/F and timing when you were staging, WOT on the brake?
You might want to split the shims in the converter 2 and 2.
#139
I can't wait to see what this thing is gonna do when I can put some power at the tree and off the line... Even those shitty short shifting runs and slow speed for the first couple hunderd feet, I still went 132 MPH in the 1/8...
#140
7 Second Club
I was @ 12.5 A/F WOT on the brake. And I "think" bumping the timing up to around 40* on the brake it might light the turbo... I think it's very close now.
Wrap all the pipes
blanket on the turbo
make sure your IC pipes are sealed
check BOV for leakage
Just to make sure....
1 3/4" headers?
2.5" crossover?
1.32 g-trim?
