ebay kit
Old Apr 5, 2011 | 06:20 PM
Chris'stransam's Avatar
Default ebay kit
Just want to know how much power can u ready be had with the shitty ebay kit if u would hack the t4 flange and weld on a t6 gt 88 and add a 4 inch down pipe
Old Apr 6, 2011 | 05:39 AM
Anyone ?
Old Apr 6, 2011 | 06:00 AM
breze84's Avatar
I wouldnt **** with it man, Everything is made with shitty quality and materials... Not worth blowing something up...
Old Apr 6, 2011 | 07:23 AM
tripblackls1's Avatar
your going to either have to modify the pipe alot or notch the frame to make a large turbo and 4" dp fit, because the pipes currently put the turbo way to close to the drivers side frame rail to make anything bigger then a 76 and a 3in dp fit
Old Apr 6, 2011 | 07:29 AM
well i planed to cut the flange and move the turbo in front and center of the motor
Old Apr 6, 2011 | 08:07 AM
Ericmck2000's Avatar
If you have the fabrication skills and money to spend when something breaks and does not fit, let us know how it turned out.
Old Apr 6, 2011 | 04:39 PM
gt35built's Avatar
If your going to do the modifications mentioned, why not get a set of truck manifolds and built a merge/downpipe?
Old Apr 6, 2011 | 08:03 PM
with what you said you would have to rework the entire kit, and at that point it would be easier cheaper and faster if you just did truck manifolds
Old Apr 6, 2011 | 08:21 PM
mike13's Avatar
Have you looked into how large a turbo you can fit with the stock ebay kit? Reason I ask is figure out where your at before you make any decisions.
Old Apr 8, 2011 | 04:09 PM
jbrenner0188's Avatar
a frend of mine had one of those kits with 3 inch downpipe and 76mm turbo and made around 550 whp if i remember right
Old Apr 8, 2011 | 06:13 PM
Yep and that's the biggest ur going get in there without modification
Old Apr 10, 2011 | 08:47 AM
Fb0dy0nly's Avatar
is there any complete ebay twin kits and is anyone using one?
Old Apr 10, 2011 | 07:23 PM
nossty1's Avatar
I had a pt88 in there but spool time is affected due to the DP restriction. Mine was a PTK not ebay so quality is better. Flip the turbo so the inlet is on the frame side and send the exhaust outside of the passenger side like a manifold kit and youll be good. Good luck with it.
Old Apr 10, 2011 | 09:39 PM
XtremeDime's Avatar
I ran the ebay kit. For the money it is hard to beat. The piping was good quality and the welding was pretty nice also. I had issues with the downpipe but I was pretty happy with it. I did 500whp with an MPT70 @ 8psi, it might have been higher but my clutch started slipping.
