car smoking a little... what do you guys think?
The car doesn't smoke at all at start up, idle, or wot. The only time is when you pull up to a stop it wil have a little cloud roll out of it and the smell of burning oil. It only does it when you first stop and not while your sitting there. Does it sound like a turbo problem? Also the turbo kit was used but I was told the turbo kit had less then 1k miles on it and the engine is very new less than 1500 miles. I don't know why but for some reason the first thing I thought was turbo seals or not a good enough oil drain.
Thanks
Thanks
5/8" drain line is recomended , Try geting on it hard and coming to a stop to see if its still there . if it is not then you probally have a bad seal seeping. My car is doing that now and if i grandma it it smokes but if i get on it every now and then then it blows out all the oil that is accumulating in the intercooler and piping. Best of luck.
