P1SC Belt noise, etc...
Old Apr 25, 2011 | 03:52 PM
Spiewalk's Avatar
Default P1SC Belt noise, etc...
i'm currently running a P1SC on my c5 LS1. The setup only has 1800 miles on on it including the belt.
The kit I bought came with a belt like this one...
However I opted to buy a new belt even though there was so sign of wear on the one that came with the kit.
This is how the one I bought looks like...
I have a ridiculous squeal coming from the belt right now and before I change the belt I wanted to know one of the 2 styles I should go with. I've narrowed the problem down to the belt, (sprayed some water on the belt and it goes quiet), and some peps from another forum told me to spray some belt dressing on. I'm kinda against that idea since everyone else has told me never to use any lubricating liquid on a serpentine belt.
Any suggestions?
Old Apr 25, 2011 | 05:19 PM
KS91Z28's Avatar
It sounds like you may not have the tenisoner adjusted to its max. Have you called ProCharger?
Old Apr 25, 2011 | 07:56 PM
flame's Avatar
Dayco belts suck. Belt dressing will make it worse. Get a Goodyear Gatorback and be done. I've been working at a shop for 15 years and our supplier switched to Dayco from Goodyear and I've had more belt problems in the last year than I had in 14 years with Goodyear. I run Goodyear on my car!
Old Apr 26, 2011 | 05:51 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd try a Gatorback belt too, I've have very reliable results with them. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old May 9, 2011 | 08:46 AM
Spiewalk's Avatar
So here is the update:
Belt changed the original belt that came with kit, not sure how many miles it had on it but it looked like it was in decent shape. Not sure about the brand. Pulleys seemed fine, (it was a PITA to deal with the old style procharger braket, tensioner setup), instal done turned car on no noise. Drove around for 2 weeks, did some WOT runs, slight chirping started to form again. At this point i'm not sure what it is. I am getting only 5 lbs of boost at the moment, still going to check for a leak but I highly doubt i'll find one. Belt slip?
I posted a few vids up and some people told me that I don't have enough tension on the belt for a 8lb setup.
Let me know what you guys think,
http://www.youtube.com/watch?v=9TrkcXuiYOs
http://www.youtube.com/watch?v=vS-KPEu7aRY
Old May 9, 2011 | 09:08 PM
flame's Avatar
It is recommended to retension the belt after it has run into the pulleys. Get a new belt put on and drive around a few kms let it cool down and retension it. If that doesn't work its time to upgrade.
Old May 10, 2011 | 08:40 AM
Spiewalk's Avatar
Forgive me for the stupid question but I thought our cars have automatic tensioners?
Old May 10, 2011 | 09:05 AM
ramairetransam's Avatar
not with the procharger its a manual tensioner
Old May 10, 2011 | 09:28 AM
Spiewalk's Avatar
Ok. Judging by the vids would you say the belt doesn't have enough tension on it? Also going to add that my kit is the early style P1SC and first gen bracket. The original tensioner just gets relocated into the bracket area, PITA to access. That means it's automatic spring loaded not manual, right?
Old May 10, 2011 | 11:33 AM
flame's Avatar
Sorry dude missed the C5 part. If its automatic tensioned then obviously you can't retighten it. The spring in the auto tensioner could be getting weak though. You could try a slightly shorter belt too.
Old May 10, 2011 | 12:31 PM
i missed the c5 part and didn't see the vid , reading comprehension kicked my butt.
Old May 11, 2011 | 11:45 AM
Spiewalk's Avatar
Thanks for the help guys. I'm taking the car to a local shop that used to do all the SLP installs back when the f-body plant was in Montreal. I did alot of reading and i'm still not sure if it's a tension issue or misaligned. A lot of websites say a chirp = misaligned, drip water and the sound goes away then comes back. Squeal = tension issue, drip water on belt and the noise should get louder.
Anyway taking the car to a shop hopefully they will figure it out and I can start producing full boost and no belt noise.
