FI with ss3600 stall
Old Apr 30, 2011 | 09:42 PM
senicalj4579's Avatar
Default FI with ss3600 stall
Im thinking about which way I should go for next big mod. It would be nice to slap a turbo or supercharger on it and be happy for a while. How would my ss3600 be with FI?
Old Apr 30, 2011 | 09:52 PM
willizm's Avatar
I was going to run about albs on my ss3600 but now that I'm going more than that I upgraded to a circle d triple disk.
Old Apr 30, 2011 | 09:53 PM
willizm's Avatar
Albs=8lbs
Damn you auto correcting iPhone!!
Old Apr 30, 2011 | 09:57 PM
LOL! Thanks! So this stall is good up to 8lbs of boost?
Old May 1, 2011 | 11:32 AM
tomz28's Avatar
turbo or SC ? pick one that would helps us help you. but last time i talk to dave the SS was only good for 600hp. and if your going turbo id send it in to get it restalled to 3400rpm. i need to do the same thing lol
Old May 1, 2011 | 12:52 PM
Sweet_SS's Avatar
I've got the SS3600 and per Yank, this converter will work great with FI. Also depends on the power/tq your planning on making.
Old May 1, 2011 | 01:36 PM
I wasnt sure but think I may be leaning to SC. 600hp would be a lot more than what I would expect. Everything on the car is stock except mods in sig. I dont plan on doing anything to the motor, trans, or 10 bolt unless something breaks and I have to upgrade. So maybe 400-500 hp to be safe? The car is 95% street car. Dave at yank said ss3600 will work great on street with Procharger and for race only with Maggie but I thought it was the other way around?
Nothing crazy. I have stock trans, motor, and 10 bolt. So 400-500hp maybe? Depends on what I could get away with without breaking to much lol
Old May 1, 2011 | 03:35 PM
Sweet_SS's Avatar
You and I are in the same boat. I'm looking for 550-600.
Old May 1, 2011 | 03:40 PM
The turbo in your sig isnt good enough?
Old May 1, 2011 | 04:36 PM
lbm13186's Avatar
if you want a car that will drive almost stock until ur push it to the ground, get f1 and big power man for a wile to go... but get a new stall bc you wont wont 8lb for long
Old May 2, 2011 | 12:26 AM
c0ncEpT's Avatar
Local C5 guy was running 10.60's full weight with his SS3600 and a Novi. Has since changed to a 3000 Vig. I think the 600hp rating that everyone has thrown out there is pretty accurate.
Old May 2, 2011 | 07:24 AM
Sweet_SS's Avatar
I plan to go bigger once I build a motor 91mm sounds good to me and if I had the $$$, twin 71mm would be put in place.
