SLP 1.85 rockers.
You guys think i should stick with the stock cam with rockers or go with the custom grind cam? Here`s the specs for the custom cam.
Dur. 226/218
Lift. .574/.564
LSA. 116 and a 113 intake centerline.
Thanks.
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Price Match Plus policy
Nate
sure the cam would make more hp at the same boost level on a turbo, because your cylinder pressure went up.. you could do the same by upping the boost a tad.
did the magnachargerabover re-pulley to get the 10hp?
if you dont have springs capable of more lift allready then you'd have to put springs on yea..
i have dabbled at the idea of doing a cam or even the new comp shaft rockers(1.8).. but i keep getting reminded to just add another psi whenever i want more hp.. i am forgetting the beauty of the turbo system.
I`ve aread done the comp. 918 swap so the springs will handle a cam or rockers but i`m thinking i`d get more out of the cam. I guess i just figured the cam would be worth another 40-60hp which would make it a worth while purchase. but if it`ll only gain me 10-20hp i`ll spend the money someplace else. Here in florida high boost don`t mix well with florida summers so i`m trying to make as much power as i can with the least amount of boost. Once i get the heads and cometics installed and get my compression down around 9:1, it`ll be about 3months and i`ll be able to get the T76 and i`m gonna tune for 12psi. But thats all the higher i want to go so it`ll still run decent in the heat.
if i do anything i'd like to fool with retarding this cam a few degrees.
i'd say you could spend the money better elsewhere.. but if you are looking to gain rumble, you should skip medium and go big
Clint
