F2 408 E85, what CR??
Some of the top guys around say that O-Ringing the block/heads is the best way to go for big boost. I guess they've had block failures before they've pushed water. Methanol will help keep the IAT's down....the E-85 is already a great foundation but any added support should help out. Is it going to be intercooled or direct to the engine? I'm not sure on what kind of boost you could pull out of her.
i know mine make 1000rwhp at 15psi, it is 100% stupid on the street with hoosier 335 drs.
at the track 15psi runs a 6.0 at 120mph. whats the purpose of your build.
for 38psi, i would think an air to water intercooler, hats off though, i get nervous at 28psi. lol
Yes i have an air to air. And I have no plans to do anything over 30lbs. Ill have to handle 20 first. The fastest pass I've ever made is a 9.88 in our carbed LS2 nova. And the highest powered car I've been in was 870 or so wheel, and I know 20lbs in this should do everybit of that.
Sorry to hijack the thread
So much for you keeping it as is for a bit! I remeber when you where pushing 800rwhp out of the stock block and you where more than happy with that! lol Is DP doing the work for you by any chance?
