F2 408 E85, what CR??
Old May 7, 2011 | 10:12 AM
Ls1manSS's Avatar
Default F2 408 E85, what CR??
Time to order pistons to finish the long block and i Need help deciding on what compression ratio to go with for my set up?
408 all forged
Mast CNC LS3 64cc
F2 procharger, cog drive
E85
This is our First build with e85 so its kinda new to us. Ill be running 25-38psi depending on the pulley. Any help is greatly appreciated.
Old May 7, 2011 | 10:28 AM
93formto98T/A's Avatar
What block? 4 bolt or 6? Even though it will be big boost I still wouldn't go much below 9.0:1 Don't think e85 will get ya anywhere near 40psi though. You'll prob need to look at e99 minimum or C16.
Old May 7, 2011 | 10:30 AM
Ls1manSS's Avatar
6 bolt
Old May 7, 2011 | 11:01 AM
Sluggish's Avatar
Most procharger builds are 9.5:1. With e85 wouldn't you wanna run higher, say 10.5:1?
Old May 7, 2011 | 11:18 AM
Ls1manSS's Avatar
That's what's I thought.. I originally was thinking 9.8:1. But like I said since were kinda new with E85 I wanted to get input on it..
Old May 7, 2011 | 11:24 AM
TurboAv's Avatar
It all depends on what your max boost target is. Since you are going to run an F2 with a 6 bolt block I'm assuming you are going to push 25-30psi+. In that case I'm not sure what E85 will support. Some of the hard core guys on Yellowbullet might be able to help more.
Old May 7, 2011 | 11:43 AM
Ls1manSS's Avatar
Ill look on there as well.
Old May 7, 2011 | 01:12 PM
Ls1manSS's Avatar
If I ran C16 what would a good CR be for that?
Old May 8, 2011 | 05:53 AM
4U2BNVS's Avatar
98Z28cobrakiller is running 30 to 31 psi on the 422 twin turbo with tc78s. Well his buddies car. It is on E85
Old May 8, 2011 | 12:46 PM
Mr.Big's Avatar
370c.i., E85 with 9.5:1 here, changing from F1R to F2 now... make sure you go with ID2000 injectors, you'll thank me later
Old May 8, 2011 | 07:29 PM
Ls1manSS's Avatar
how many lbs. you plan on running?
Old May 8, 2011 | 10:53 PM
Mr.Big's Avatar
26 with the F1R so probably low 30's with the F2...
Old May 9, 2011 | 06:34 AM
Ls1manSS's Avatar
So I assume that you don't think you'll need more than E85 as someone mentioned above. We have similar builds, I just have a stroke.
Old May 9, 2011 | 12:10 PM
Mr.Big's Avatar
E85 and C16 tunes for me yield almost exactly the same tq and hp... E85 is the ticket!!!
Old May 9, 2011 | 12:14 PM
Mr.Big's Avatar
To be clear I also run a 3 nozzle methanol system, one nozzle being pre compressor... We have tried so many different combinations to my setup since the first time we went F.I. with it back in 2005, this is the 10th iteration...
Old May 9, 2011 | 02:04 PM
Ls1manSS's Avatar
This is my second F.I. car, but first with E85.. and what rpm you plan on spinning yours..
Old May 9, 2011 | 07:03 PM
Mr.Big's Avatar
Same as current, 7200rpm, only changes are a trick new bracket designed for the F2 with more "beef", COG/Sprag drive instead of current 10rib direct drive, and F2 in place of F1R
Old May 9, 2011 | 08:08 PM
gennex's Avatar
E85 has been pushed to 30psi without an intercooler on many big block applications, and well over 30psi in the supra community, 30 seems dooable, 38psi, you might be the first LS guy in that territory on E85.
Old May 9, 2011 | 08:10 PM
blue00ZZleeper's Avatar
Mr Big do you have any problems pushing water/lifting heads? Is it a standard MLS gasket or a O-Ringed setup? I'm just wondering how far I can push her and what boost level she will take before she pushes water. To the OP on E-85 I would aim for a 10.1:1. It leaves you a decent amount of room for max boost but will also be nice down low. Not that its relevant but what car is it going in? That will make for a nice combo!
Old May 9, 2011 | 09:26 PM
Ls1manSS's Avatar
im running a o-ring block but dont know more since its not complete yet. but would you think meth would get it to 38psi??? im really not trying to run more than 30 but just a question in theory.
