New Turbo "In"... Tuning Tonight!
Old May 11, 2011 | 08:51 AM
HydroStream6's Avatar
Default New Turbo "In"... Tuning Tonight!
Well my PT7875 arrived yesterday
Got the TC76 out and snapped some pics of the two next to each other. The 7875 is definitely larger, but it fit!
I need to trim some sheet metal around the compressor outlet since it's a little "longer". Going to do that tonight and start tuning.
I'll update here as I progress. Thanks to everyone for all of the info that everyone has helped with with in choosing my new turbo!
Attached Thumbnails New Turbo "In"... Tuning Tonight!-pt7875-1.jpg   New Turbo "In"... Tuning Tonight!-pt7875-vs-tc76.jpg
Old May 11, 2011 | 09:37 AM
SPRAYED 01's Avatar
Nice, can't wait to hear results. I just swapped out my tc78 for a comp 8079 with billet wheel. What's your engine trans rear consist of?
Old May 11, 2011 | 10:05 AM
rotary1307cc's Avatar
you will like it, let us know how it works!
Old May 11, 2011 | 11:16 AM
JAX04's Avatar
Hell's yeah! Keep us updated bro!
Old May 11, 2011 | 11:40 AM
How much did the Comp 8079 billet set you back?
Engine is a forged 370, Diamond dished pistons, Scat rods, stock crank, LS6 cam. ~9.2:1 compression. Stock 317 heads with studs and 3 layer MLS gaskets.
Trans is a home built 4L80e with TCI computer.
Rear is stock with 3.46 gears and upgraded shafts.
I'm done at 3 today so I should be able to get it running in a few hours. Will be interesting to see how much AFR changes with JUST the turbo swap.
Old May 11, 2011 | 12:27 PM
TracyRR's Avatar
hey hydro, looks great..... it looks quite a bit larger than the tc76 from the pic.... what are your power/et goals?
Old May 11, 2011 | 12:33 PM
I don't really have a power goal. Just faster than it is now haha. I'd like to see 9s and low 140s out of this setup in my 4100lb car.
Old May 11, 2011 | 12:48 PM
JAX04's Avatar
I certainly wish you the best of luck with this goal man!
Old May 11, 2011 | 04:43 PM
overhere's Avatar
cant wait for an update!
Old May 11, 2011 | 04:51 PM
black98ws6ta's Avatar
It should pick up quite a bit I would think. The modular motors love that same upgrade.
Old May 11, 2011 | 04:53 PM
TurboTerrorLS's Avatar
very nice. i have a Precision 78mm as well. GREAT TURBO!
Old May 11, 2011 | 07:26 PM
MUSTANGBRKR02's Avatar
Very nice. I already want a better turrbo then my TC78 only have 1k miles on it in about a year lol.
Old May 12, 2011 | 07:01 AM
Got her up and running. So far so good. Definitely less back pressure. I had to run an 18lb spring in the gate with the TC to get 15lbs boost. I unscrewed the boost controller all the way and the first time I romped on it, it went right up to 18lbs. Forgot I had that heavy of a spring in there. So back pressure is down for sure. Swapped to a 12lb spring and did some pulls on 12lbs and then cranked the boost controller up to 14lbs when all looked good. Feels pretty good so far. Going to keep upping the boost slowly as I tune. I'll keep the updates coming!
Old May 12, 2011 | 07:03 AM
JAX04's Avatar
Videos!
Old May 12, 2011 | 08:11 AM
TracyRR's Avatar
Good to hear
Old May 12, 2011 | 10:28 AM
I am surprised that it's not taking much more fuel. It was tuned pretty rich on the TC, high tens across the board at 15psi. On the new turbo, at 14psi, without changing the fueling, it's like 11.5and dips down to about 11.1. So it kinda tuned itself haha. I'm just surprised it's not leaner. Going for more boost tonight after work. Hope the heads stay where they are!
Old May 12, 2011 | 02:18 PM
stock48's Avatar
9 Second Truck Club
Thats still prob a couple mph at the ssne boost. I think your big gain will in the 16-18psi range where the tc runs out. My Garrett GT 76 picked up a solid 5mph over the tc76 at same 16psi can't wait to see what 20 does:/
Old May 12, 2011 | 03:20 PM
Yea I'm hoping it picks up a good amount. As long as the heads stay down we'll be finding out what 18-19lbs is like 317s with 6L mls gaskets and studs.
Old May 12, 2011 | 04:19 PM
Nitroused383's Avatar
If not I'd say it's time for some LS9 gaskets. If you have any logs / scans to compare spool up rpm of the two turbo's I'd appreciate it. People say this turbo should spool similar to the TC76 but I don't believe them without seeing data Maybe in your case of being on a 370 it will spool quicker with less back pressure.
Old May 12, 2011 | 05:48 PM
Tally TransAm's Avatar
im gonna be paying attention to this one. if/when my tc76 gets maxed out, this turbo is high on my list
