P1sc1
My buddy wants to sell his procharger and I was intrested, but Im not sure what all I need, he says I'll get the procharger and all the piping, but Im not sure what else I'll need, he wants like 3,500 for it, but I was thinking about going H/C, witch way to go is better, and how much power can I get out of the procharger with out blowing out my stock bottom end?
Check the FI reliability list sticky.
Most people can run 8 psi with no problems as long as their tuner is competent.
Higher boost than that could necessitate forged pistons, ARP rod bolts, methanol kit, etc. but key is a good safe tune from someone who knows what they are doing.
LS1Tech Sponsor
8 psi will generally get you an additional 140 rwhp, plus at normal part throttle driving your fuel mileage won't be affected.
Here is an older copy of the ProCharger installation manual that an old customer of mine put out on the internet. http://www.ls1.com/ed/procharger_owners_manual.pdf
I sell most of the piece parts that are required at the link here.
http://shop.brutespeed.com/98-02-F-Body_c181.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
LS1Tech Sponsor
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Correct! Bob
__________________
LS1Tech Sponsor
Here is a link to my blower cam.
http://shop.brutespeed.com/Comp-Brut...n-Camshaft.htm Bob
__________________
Ok what about heads, do I need heads with big intake runnrs ans big combustion chambers, aslo whats the best intake manifild to go with, is the fast 104mm to big, or is the 92 better?
With a stock bottom end get some 317 heads or use your stockers with upgraded valve springs and pushrods. For your intake manifold I would use an LS6. Most later model LS1's already have them or you can find em for a couple of hundred dollars on the forums used. The FAST is not going to net you much more HP over the LS6 and it costs lots more.
what about gears, how big can I go, is 3.90 to big? and should I upgrage my rear end? I wanna get as much power as I can without blowing the stock bottom end, I can get 525-570hp to the wheels?
