Carbureted, 11.3-1 compression and 7 lbs of boost. can it be done?
I have a LT1, Blow thru Carbureted, forged 383 shortblock, LT4 heads, and a front mount turbo
![](http://i2.photobucket.com/albums/y29/96lt4/2d99aac5.jpg)
problems is, its 11.3-1 compression... and pump gas (93)
I do have meth injection
Would it be possible in ANY way to run 7-8 lbs of boost on 93 octane?
otherwise, ill have to switch to E85
i am going to up it to 10 lbs here in the next week or two
i honestly dont even think it could run on 2 deg
im going to throw 2-3 more lbs and a another deg or two of timing and see what happens.
I think it can be done on pump 93 because you are carb'd. The carb kinda acts like meth injection on an efi car, cooling down the intake charge before it hits the cylinders. I would make sure you turn the timing way down to keep detonation at bay and watch your tune. I would go no more than 6 psi though.
LS1Tech Sponsor
Back at the old EPP shop we did an APS turbo on an LS2/402 11.0/1 Firehawk. 93 octane and 100% methanol and it ran great at 7 psi. You have a wet intake manifold which will help, I don't see you having any problems once you get it dialed in. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
