D1SC set up with IPS tune finished
#41
Strange that combination is only giving you 10psi.
That is the same combination I am using on my 383, ported 317 heads, making 13.5 - 14 psi and 715 hp.
Maybe it is the cam difference, mine I think is a Cam Motion 224/240 620/612 116+4. Or the FMIC I have instead of the twin intercoolers.
I just would have expected a lot more boost out of your 347 with that pulley combination.
However, at the 10psi getting to your motor those are some stout numbers.
Good luck with keeping it alive. My stock engine didn't survive 3 months.
#42
#44
Not sure right now, I am still doing research on it. I will probably get a smaller pulley for sure. I would like to run meth if the tune can make the engine live a long life, but I don't want to be going through a ton of it. I don't want to have to monitor and check the meth level constantly and be filling it up with every gas fill up. I went FI and not nitros because it is something that might run out. I could have went nitros and saved a ton of money but wasn't interested in the constant fill ups.
#46
UNDER PRESSURE MOD
I'm also looking into methanol as well. I've heard it's a good safety measure especially on a stock shortblock. I plan to use my windsheild washer resevoir as my 'tank' so that has a low fluid sensor, which I should probably test first to make sure it works since I don't think I've gotten low on washer fluid in the 11 years I've had my car.
From what I understand, it is boost activated, so unless you do a lot of high rpm, high boost driving, it's not going to be used as quickly as you might think. I plan to buy it in 5-gallon cans, so having enough shouldn't be an issue.
#47
^^ Yes ^^
02SOM's objections to a methanol system made me chuckle - sorry.
My Alky system only sprays the meth at WOT and uses the windshield washer reservoir. Fill it up once and it lasts a long time - or at least it does for me. It would depend on the driver's habits of course, but I think you'd either have to drive like a jackass or run 10 passes down the track every weekend to worry about the level constantly.
Yep, VP Racing 5 gallon can of M1 and you are set.
#49
#50
^^ Yes ^^
#51
OK so in your situation it sounds like it was more of a tuning and set up problem than it was the fact of the higher than 8psi boost.
#52
I am glad I could brighten our day . I understand that it is only sprayed at high rpm and boost and my understanding is you can program this based on the system. All that being said I still dont have any frame of reference on how long it lasts, you did shed some light on it though. I just dont want it to become something I always have to worry about. I take some long trips too such as power tour and I am a little worried about having to pack some away in the cab in a container to take with me. I guess I will understand how much I go through when I get the system put on. Sorry it isn't like you just run to the local Walmart to pick up a gallon of meth. Thanks for the reply.
If you do a lot of just normal driving you are barely gonna use any. You will obviously use more when you are racing and stuff but it isn't that bad. Not nearly as much of a pain as filing a nitrous bottle
#53
Brother, I wish we could. There is one performance shop in town here that always has it... but only one. I think some of the "tuner" shops may carry meth but not sure because I am not into imports much so I don't frequent those shops. Luckily like I said, you buy a 5 Gallon drum and you should be stocked up for a long time unless you are beating on the car constantly.
#56
I run 100% pure medical grade methanol, I lose more methanol from evaportaion in the heat when my car sits. Our cars do not have a low fluid level sensor, but Julio @ Alky Control can fix that for you. If you're ever in a out on the road or something you can run to walmart, just buy peak blue -20 and throw in 2 bottles of heat. Good in a pinch and about 50/50 water meth after 2 bottles of heat.
#57
#58
#60
LS1Tech Sponsor
Methanol can easily drop the inlet air temps by 35 to 40 degrees, it makes a huge difference in the power. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
