78 vs. 90 vs. 102. vs 4150
so im about to do an intake swap on my truck. right now it has the bone stock truck intake with stock 78mm TB. its a stock 5.3 with stock heads and 225 581 cam. it already made close to 800WHP on a mustang dyno with alot of boost FWIW.
but my question is if there is gains to be had with a larger TB or if i can get the same power if i just run more boost?
thanks for any help!
i'd wait til you build a motor, upgrade the turbo, and im guessing you have 3" IC piping, upgrade that to 3.5 or even 4" depending on your planned power level. i doubt there will be much of gain otherwise, and you're walking a pretty fine line with the stock 5.3...
awesome power, btw. good luck.
No, I have a 4l80 with about a 3400 10.5" stall.
I'm leaning towards the proflo with my 78mm TB.
As far as goals go, idk really... I've never gotten a clean pass out of the truck yet but as it sits now it could probably go 10.5 or so. I'd like to think it has a 9 in it somewhere but obviously that'll take some work. It's not easy to make a daily driver extended cab truck go fast! Haha
