My custom C6 91mm turbo build thread! DYNO VIDEO ADDED!
Old 09-23-2011, 11:30 AM
  #61
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by camaro383
Do you have a filter to recomend otherwise
The turbo flows around 2050CFM at max operating cycle.
Old 09-23-2011, 06:05 PM
  #62
camaro383's Avatar
So wut about a filter?? Do you have one in mind that would be better than the k&n
Old 09-23-2011, 06:22 PM
  #63
KILLER-LS1's Avatar
Originally Posted by DrTurbo
Congrats on the build. Only problem I see will be that airfilter. WAY to small to feed that monster. It will start puking oil once you turn it up. Cause a big vacuum.
Can you explain this a little more? I have the same turbo and the same filter, and i noted that there is red filter oil sprayed all over near that filter. I also notice that the turbo is leaking externally a little bit and have no idea why.
What would be a good alternative? thats the biggest filter that K&N makes for a 5" flange
Old 09-30-2011, 01:44 PM
  #64
98silverbullet's Avatar
http://www.youtube.com/watch?v=Yw6WkeIvF58&hd=1
http://www.youtube.com/watch?v=ewNLf2SfD0M
http://www.youtube.com/watch?v=iSR9L...eature=related
Old 09-30-2011, 03:46 PM
  #65
camaro383's Avatar
I heard u went to the farm today for ur first dose lol
Old 10-02-2011, 09:32 AM
  #66
offaxis's Avatar
Awesome! A little bird is telling me there will be dyno pulls tonight. Cant wait to see the numbers.
Old 10-03-2011, 12:51 AM
  #67
camaro383's Avatar
ya seems tonight there was no one around to let us blow thier dyno up so we put the street to use and got her up to 17#s of boost and i can tell you this, there is almost no lag and even with 345 mt et street radials 3rd gear is useless lol
how bout a custom 4" exhaust with a race muffler and turndown
Old 10-03-2011, 02:09 PM
  #68
camaro383's Avatar
So we got some dyno time in this morning and boost seems to be falling off at 5krpm, its not spark blowout or valvesprings because i even backed down the boost a little and same issues remains i even icreased timing a couple of degrees and nothing and its not breaking up...
I didnt hook up an exhaust backpressure gauge yet but im sure that the ratio is over 1:1 cause its a 418 with a t6 on a 1.08a/r exhaust housing.. I think i need a stiffer wastegate spring because its only a 7# spring and im sure as the rpms increase the added backpresdure is pushing the gat open resulting in lost boost...
Wut u guys think, am i aiming in the right direction, ill get the graph up in a little, u can see it crest and then start to fall of around 5krpm
Old 10-03-2011, 02:12 PM
  #69
LS1TECH Sponsor
DrTurbo's Avatar
Yes you are. A 418 is a big boy.....needs lots of turbine flow indeed.
Old 10-03-2011, 02:20 PM
  #70
camaro383's Avatar
Well right now i have the heaviest spring that came with the jgs 60mm gate, u think if i added the light spring to it i should be good to go?
Old 10-03-2011, 02:21 PM
  #71
LS1TECH Sponsor
DrTurbo's Avatar
You can stack the springs
Old 10-03-2011, 02:24 PM
  #72
882/826 at only 5k rpms boost creeping off after that
http://www.youtube.com/watch?v=Py-0CJVtEhY
Old 10-03-2011, 02:38 PM
  #73
offaxis's Avatar
Baddass man . Now stack some springs and get back on the rollers.
Old 10-03-2011, 02:43 PM
  #74
JohnnyBz28's Avatar
now send some money my way LOL
Old 10-03-2011, 03:16 PM
  #75
camaro383's Avatar
Sorry my friend had it printed out in mph instead of rpm but u can see how it falls over
Old 10-03-2011, 03:18 PM
  #76
camaro383's Avatar
Looks like 900 woulda got passed up quik if the gate woulda stayed closed lol
Old 10-03-2011, 03:27 PM
  #77
offaxis's Avatar
STD corrected dyno sheet is just another reason to hit the rollers again soon
Old 10-03-2011, 03:37 PM
  #78
camaro383's Avatar
Lol i dont believe in corrected numbers, this is how much power it made then and there, i dont think people correct their 1/4 mile times when theres a low da and the temps are cool outside so y should u do it on the dyno, unless of course ur doing it for tuning wise
Old 10-03-2011, 03:38 PM
  #79
offaxis's Avatar
It is corrected to Std though not uncorrected but I was joking about that just want more numbers
Old 10-03-2011, 03:56 PM
  #80
Tiago's Avatar
deffinately need mor WG spring.
Quick Reply: My custom C6 91mm turbo build thread! DYNO VIDEO ADDED!
