My custom C6 91mm turbo build thread! DYNO VIDEO ADDED!
Ok guys so long story short last year the car had a A&A Blower on it and the timing chain broke on me, and as you know down time really gets you thinking crazy things and thats how i got here lol ok first some back info!
Last Build Thread:
http://www.svtperformance.com/forums...ech-build.html
Last few Runs:
https://ls1tech.com/forums/multimedi...ortech-c6.html
https://ls1tech.com/forums/multimedi...rs-racing.html
https://ls1tech.com/forums/multimedi...x-eclipse.html
https://ls1tech.com/forums/multimedi...9-tribute.html
The break down of whats going on:
08 C6 Z51
418 LS3 By Lab of Lindenhurst.
-Callies Compstar H beam Rods
-K1 Forged Stroker Crank
-Wiseco forged -32cc coated pistons
-67cc LS3 Heads done by Frankie Ford(local Guru)
-ARP Head studs
-Comp Cams 247/247 627/627 118LSA
-Katech C5r Chain
-Ported LS3 oil pump
-Yella Tella Rockers
-Ati Super damper crank pulley
Fuel System:
-Stock pump with an external Fuel Lab 1500hp pump
- -8 Feed and -6 return
- Fuel Lab boost ref. Fuel pressure regulator
-FIC 1300cc Fuel injectors
-Aeromotive Fuel rails
Turbo kit:
-Custom hot and cold side using all V-bands
-CX Racing 5" thick Intercooler
-Garrett T6 GT 91 Turbo with a 1.08 A/R
-JSG 60mm B.O.V and Wastegate
-Custom Griffen Radiator with -24an fittings
Drivetrain:
-Stock Rear and Trans(for now) with DTE BRACE
-Spec T-Trim Twin Disk Clutch
-CCW DRAG PACK 17x4.5 & 18x12
Big thanks to American Racing Headers who are local to me for hooking me up with a great price on all piping! Thanks again Nick!
To 03Cobrra on here who is helping like he always does
and my friend Matt whos the main man behind this project Camaro383 on here. All work is done in our garage !! Also a big shout out to Brian @ Hinson supercars for the hook up on parts! And Jose @ forced inductions for the turbo,wastegate,BOV,blanket and more! Got everything fast!!
Pics:
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_3788.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_3780.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_3774.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4005.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4001.jpg)
New Rear Z06 Fenders with the other parts
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1720.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1721.jpg)
External 1500hp Fuel pump
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1722.jpg)
60mm Wastegate and BOV, Turbo Blanket and more:
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1724.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1726.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1729.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1732.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1735.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1740.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1741.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_1742.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4021.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4020.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4082.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4179.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4236.jpg)
Motor waiting to go in!
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4234.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4243.png)
ok ok Lets get to work!
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4200.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4204.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4208.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4211.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4212.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4241.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4244.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4274.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4247.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4260.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4269.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4270.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4273.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4271.jpg)
New Add ons to
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4256.jpg)
Our new wall mounted 42" flat screen lol :beer:
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4258.jpg)
![](http://i319.photobucket.com/albums/mm452/JsBc6/IMG_4265.jpg)
And thats all for now! Hope you guys stay tuned! alot of work on the way and ill keep updating!
Last Build Thread:
Last few Runs:
08 C6 Z51
-ARP Head studs
-Katech C5r Chain
Fuel System:
Turbo kit:
Drivetrain:
Pics:
New Add ons to
Just to give you a heads up that 1.08 housing on that turbo with the 418 might be too small. I am running the same exact turbo setup on a 390 and at only 8 psi was seeing 15 psi of backpressure which was opening the wastegate early on me so I am stepping up to a bigger turbine housing. Just something to look at when you get her going.
Ya im building the car, and jose at forced inductions said this size housing wouldnt be an issue till over 1000whp, it sounds like u may have other issues causing too much backpressure cause on a 390 that housing is plenty big enough
