turned up the boost, but don't feel it
Have a mustang with a ls6 T70 turbo, was running 4.5 ps1, turned it up to 9 and don't really feel much of a difference, is that normal?
No boost leaks, I didn't look at the boost gauge, slot the rubber piping that I have turning into the throttle body is really soft and when I give it gas it sucks down if that would make a huge diff
It does suck down till about 4-5k rpm, I understand what your saying about it ballooning, but it doesn't balloon when parked and I rev it all the way up, I'm guessing it will when its under load when I'm driving it
Get a new intake elbow although I don't think that's the problem. Also that's a very small turbo. As you go higher in boost you will notice a smaller and smaller gain due to back pressure
I'm going to order a elbow for it and see what happens, so what turbo should I get, it has a t4 flange. It made around 600 rwhp with the t70 and 9ps1 on the dyno, I'm pushing for 700rwhp. Also not sure how much boost the ls6 will hold, has arp rod bolts and head studs
I would at least get a tranny cooler and shift kit at the very least until it burns the clutches up and then build the **** out of it or swap in a 80e or TH400. I wouldn't think it would be the turbo that is holding him back to much at only 9 lbs. At 14-15 maybe, but 9 no. If the elbow is getting sucked closed at all it's not going to matter how big a turbo he puts on it.
