Post your PUMP E-85 boost combo
Old Jun 25, 2011 | 12:47 AM
I_Need_Land's Avatar
Originally Posted by grr
i blocked off half the housing one day to see how a spool valve setup would work and it was almost undrivable.
awesome.
Old Jun 25, 2011 | 08:09 AM
71 chevy's Avatar
Originally Posted by wills55
Serious setups guys. Is it safe to assume that there is a big enough tuning window with the pump E-85 that you can get pretty aggressive with the tune ups in your street cars and not worry about the inconsistencies in ethanol content of the fuel? I ask because Ive read that it varies from as low as 70 percent to the upper 80's in the pump stuff.
after e50, the increased knock resistance of ethanol fuel is negligible. ie e50 vs e100 = pretty much same knock resistance
Old Jun 25, 2011 | 02:39 PM
wills55's Avatar
Thanks 71 chevy. Thats pretty much what I assumed but I just wanted to hear it from someone with experience.
Old Jun 25, 2011 | 03:49 PM
71 chevy's Avatar
here is the research
http://delphi.com/pdf/techpapers/2010-01-0619.pdf
Old Jun 25, 2011 | 08:47 PM
wills55's Avatar
Thanks for posting the reading material 71 chevy. Looking forward to seeing more combos from you guys.
Old Jun 26, 2011 | 10:38 PM
wills55's Avatar
bumping this up to the top. I know there are more guys on here running e85 than this. Lets see some more corn powered cars!
Old Jun 26, 2011 | 11:21 PM
massconfusion's Avatar
god i cant wait to run corn on my car. i half wish this was a sticky!!
Old Jun 26, 2011 | 11:46 PM
slowlsx's Avatar
How much power do you guys think stock feed line can be made with E85? I have 92lb injectors at 58psi ad dual 255 pumps on stock feed lines (only temporary) on 6-8psi... Will it be fine till I get the -10 feed in there? I really wanna go straight to the good smelling corn!
Old Jun 27, 2011 | 01:03 AM
skinnies's Avatar
790rwhp is what automagic made on the stock feed line on e85, I personally don't think the lines are the restriction on that setup, the pumps I think will run out first.
Old Jun 27, 2011 | 02:17 AM
slowlsx's Avatar
That's good too know! I think I'll switch to the aeromotive stealth pumps pretty soon! Those should hold up alot better then the 255's
Old Jun 27, 2011 | 07:25 AM
pwrtrip75's Avatar
CID - 370ci. 9.8:1
Heads - 317's stock valves, bowl ported by me.
Cam - Speed Inc's TU1
Intake - Vic Jr. w/ edelbrock low pro elbow
Turbo, Twin Turbo or Blower - Single PT76GTSH
Tuning software or Aftermarket EFI - Stock PCM - HP Tuners 2-bar SD
HP/ TQ if known and e.t. and MPH - Currently unknown - still test/tuning - Should be good for 800-900whp
Fuel pump and fuel line sizes (if not using stock fuel lines) - Dual Walbros (installing a 3rd). -10 feed line. Billet Atomizer 160# high imp injectors.
Old Jun 27, 2011 | 11:22 AM
  #32
wills55's Avatar
Nice setup in your TA pwrtrip75 looking forward to hearing what it runs.
If we get enough cars running e85 in here maybe we can get the mods to stick it to the top. Would be nice to know what everyone is running so that new guys know what the fuel is capable of in a boosted application. Keep 'em coming guys.
Old Jun 27, 2011 | 09:06 PM
  #33
gsxr1k2's Avatar
CID - 404ci. 9.5:1
Heads - prc 2.5 5.3's
cam - zo6
Intake - ls6
Turbo, Twin Turbo or Blower - Single gt-91
Tuning software or Aftermarket EFI - Stock PCM - HP Tuners 3-bar SD
Fuel pump and fuel line sizes (if not using stock fuel lines) - Dual Walbros and 160# high imp injectors.
Old Jun 27, 2011 | 10:28 PM
  #34
Boosted3rdGen's Avatar
Originally Posted by jasond26
LSX 427 8.5cr
WCCH lsx-ls7
HKE turbo cam
PI/MAST 4500 ported/polished intake
PT-106 1.32 ar 14lbs on the spring
BS3
Aeromotive belt drive pump
Atomizer 225lb injectors
Just got it running yesterday thanks to some helping hand from this site. Times coming soon. E-85 smells soooooo good...lol.
http://www.youtube.com/watch?v=Yzc52...el_video_title
I love it, is you bov open at idle?
Old Jun 27, 2011 | 10:37 PM
  #35
bpope's Avatar
PUMP E-85 combos ONLY.
Let us know your:
CID -- 370 C.I., 9.0:1
Heads -- Lightly Ported 317s
Cam -- EPP Blower Cam
Intake -- LS6
Turbo, Twin Turbo or Blower -- D1SC Procharger, 9 PSI
Tuning software or Aftermarket EFI -- Stock ECU HP Tuners
HP/ TQ if known and e.t. and MPH -- 10.56 @ 131, 1.78 60 Foot, estimtated 625 rwhp
Fuel pump and fuel line sizes (if not using stock fuel lines) Twin Walbros, -8 Feed
I definately think the car will run some 10.20's or 30's if it would just hook up on 9 psi. Currently making 14 psi and hoping for some high 9 passes.
Old Jun 29, 2011 | 02:50 PM
  #36
wills55's Avatar
Nice to see another blower car on the list. What gear are you using in the rear? Those are some good e.t.'s for just 9psi.
Old Jun 29, 2011 | 03:25 PM
  #37
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I really wish we could get E-85 around here, but it is completely non existant.
Old Jun 29, 2011 | 05:15 PM
  #38
Milk Man's Avatar
Still being built but this is my setup:
370, diamond Pistons 9:1cr, Callies rods, stock crank
Stock 317s, ls9 mls gasket, head studs
Speed inc tu1
Ls6 intake
S475 turbo @ 20lbs (if it holds)
Stock pcm, HP tuners
800rwhp goal thru a th400 and 9"
Old Jun 29, 2011 | 05:36 PM
  #39
Pony Exp.305's Avatar
Thumbs up 1998 T/A +stockLs1 been run E85 mix 89or93 for 2 years
Have been NOT trouble with stock Ls1/Auto. over 170K miles on (3/4of a tank) E85 mix (1/4) Gas 89/93 for +2years...
In E.Tennesse E85 cost 3.19 p/gal.<<Too high
Will pixes or video here later..
Old Jun 29, 2011 | 11:33 PM
  #40
rotary1307cc's Avatar
CID- 370 10.0:1 CR
Heads- WCCH LSAs
Cam-232/242, 113lsa
Intake-l76
Turbo, Twin Turbo or Blower- single 78GTS
Tuning software or Aftermarket EFI - 2bar HPT
HP/ TQ if known and e.t. and MPH - not known
Injectors- ID1000s
Fuel pump and fuel line sizes (if not using stock fuel lines) - magnafuel pump, -8 feed
