Stay Procharger or go Turbo?
Old 06-26-2011 | 07:04 PM
  #61
rossi89's Avatar
Turbo for sure.
Old 06-27-2011 | 07:12 AM
  #62
Need_a_Camaro's Avatar
You should come to our Cruise in @ Mayhew Chevy in Romney next month. My car will be finished and will be there with the shop that's building the turbo kit. We'll see how a 408 and a TH400 does with a 91mm.
Old 06-27-2011 | 07:55 AM
  #63
Packy's Avatar
Originally Posted by speedracer5532
The blower does have me discussed at the drag strip. I basically don't want to even take it to the track because probably the last 5 times or so I have had issues. I do think things are pretty well ironed out with the blower but I have yet to have a good clean pass in a while. Giving up on the 8-rib belt and switching to a cogged setup and adding bracing to keep the blower bracket from flexing has basically eliminated any belt issues I think.
Just my .02 cents. You should go auto first with your S/C set-up properly to see how you like it on the street and how much time you drop at the track. I have had more fun on the street with my TH-400 than I ever did with the six speed. If you are not satisfied then move on to a turbo set-up. I would also think that some of your belt issues will be diminished or disappear with an auto set-up.
Old 06-27-2011 | 09:24 AM
  #64
helicoil's Avatar
Belt issues should be a thing of the past on F-bodies.
Old 06-27-2011 | 09:26 AM
  #65
speedracer5532's Avatar
I said I have a cogged setup now and agree I think belt issues SHOULD be solved.
Old 06-27-2011 | 09:34 AM
  #66
helicoil's Avatar
Just in case they are not ^^
Old 06-27-2011 | 09:38 AM
  #67
And the price of that guy's setup isn't cheap. I'm done spending money on solving belt issues with a Supercharger. I have my bracket braced good now and it seems to be good.
Old 06-27-2011 | 10:07 AM
  #68
turbocamaro125's Avatar
turbo needs bracing to john lol cause the ******* turbo is big...106mm
Old 06-27-2011 | 10:11 AM
  #69
Lmao...I don't have an Outlaw drag radial car...D-bag.
Old 06-27-2011 | 11:16 AM
  #70
BrianC98Z28's Avatar
helicoil is that a cog setup on your D1sc??
Old 06-27-2011 | 11:31 AM
  #71
well you should have a Outlaw car.....
Old 06-27-2011 | 12:22 PM
  #72
NO...street car.
Old 06-27-2011 | 01:37 PM
  #73
you can street a 106.....
Old 06-27-2011 | 02:30 PM
  #74
Fbodyjunkie06's Avatar
With my 80e it makes spooling my little 76mm easy as cake. At 2600-2800rpm I am out of vacuum and by 3000 im in a pound. By 3500 I'm at 6-7 pounds and by 3800 where I launch I'm at 8-9. 4000rpm 11#'s and it comes really quick, I don't ever notice it at the track only on the highway,.
Even with the belt situation fixed it will always be in the back of your mind as a big what if. Turbo solves that really easy. I don't think you need to go that big on your turbo choice unless you want to really run outlaw dr. MM has a 91mm turbo and he can turn the wick up to 1300whp which hasn't been needed yet to run 8.5x's with a 3750# car.
I think a PTE 88 will be more than enough for what you want.
Quick Reply: Stay Procharger or go Turbo?
