Who has the fastest stock 6.0L here
Thanks for all the help smart ***. I am building an '87 300 zx with a stock 6.0L out of an escalade with a 76 mm turbo E85 blow through with a hundred shot of gas 4l80e and '02 zo6 cam and would like a little comparison. I see all these people using 5.3's with stock bottom ends and stock bottom end stock cube motors but most 6.0 builds have big cams and ported heads.
I'm wondering if a stock 6.0 with the same boost as a 5.3 will make more power.
Which stock bolts are talking about?
This is a good question..
How fast can you go without spending $500+ dollars on upgrading the bolts and gaskets on a stock Truck motor, or LS.
That practially doubles the cost of the pull-out engine. Is it needed?
To run a nine in a 3800 lb car, I know it is not.
To run an eight in a light car, problably not, since a 3400 lb car can go low 9's on stock bolts.
Glad to see more people pushing them with out the "insurance" of the upgrades, on an engine that costs..... not much, until you add up the time and money of upgrades.
