Best intake for forced induction...
Old Jun 25, 2011 | 01:01 PM
Phil99vette's Avatar
7 Second Club
Originally Posted by 6techniques
gorgeous!!!
Soon to be 6sec. car???? Damn you are not playing around!
Well considering it went 7.2x @ 3300# and it knocked out a cylinder at the 1/8 mile that run, yes. Its 300# lighter and should make more power. From that hit, we've went .13 faster to the 1/8 mile still at 3300.
Old Jun 25, 2011 | 02:36 PM
venom ws7's Avatar
Nasty looking intake.
Good luck with the new setup Phil..
Old Jun 25, 2011 | 02:55 PM
speedracer5532's Avatar
Originally Posted by jetaws6
You do realize he has a 7 second car right?
Yes I know what Phil has and agree for what Phil is doing that probably is the best intake for him but its not the best forced induction intake for every single forced induction setup.
Old Jun 25, 2011 | 04:03 PM
7 Second Club
Give me a couple of combos and which intake you feel is the best. If I built a 427/383/347" street car with any cathedral or oval port, its going to have a custom manifold from John on it. airflow distribution says its the best IMO.
Old Jun 25, 2011 | 04:20 PM
Adam Connell's Avatar
Anyone know a ballpark figure for one of these works of art?
Old Jun 25, 2011 | 05:22 PM
Stock cube budget build I would probably say a LS6 intake...wouldn't be cost effect to spend 3K on a custom manifold from John or even a built 427/383/347 build that someone is planning on running hydraulic lifters and not planning on spinning it above say 6700 rpms wouldn't start to see the advantage of the sheet metal manifold.
Old Jun 25, 2011 | 05:48 PM
7 Second Club
Do you think there would be a difference in airflow distribution over a LS6? Sure if your building a 450hp setup you have a point.
Old Jun 25, 2011 | 05:58 PM
At 6K rpms not much but at 8K rpms then yes there would be a big difference.
Old Jun 25, 2011 | 06:16 PM
7 Second Club
You would be surprised if you saw the data.
Old Jun 25, 2011 | 07:39 PM
onfire's Avatar
Coal Mining Director
You guys test the airflow distribution of an LS7 intake? Only data that I have is the sparkplugs...looks pretty close.
Old Jun 25, 2011 | 08:03 PM
LC's Avatar
LC
I just wish he could make them faster...
want one, but can't wait 6 months for it.
Old Jun 25, 2011 | 08:23 PM
  #32
LASTLS1's Avatar
6 Second Club Moderator
His intakes look like art.
Old Jun 25, 2011 | 08:47 PM
  #33
trans2000am's Avatar
does he make 1 that fits under a stockish style hood?say same height as a vicjr and aaron elbow? how would flow be?
Old Jun 25, 2011 | 08:57 PM
  #34
TracyRR's Avatar
Intake **** for sure! Congrats to you and tom
Old Jun 26, 2011 | 09:19 AM
  #35
1fast bird's Avatar
Marcella's welds look like a machine did them. Unreal quality and no doubt the best of the best.
Old Jun 26, 2011 | 03:40 PM
  #36
Fbodyjunkie06's Avatar
Man it does not matter if you are spinning it to 6500 or 8500 it's about getting air equally into every single cylinder. Why do you think they have EGT probes on each cylinder? So they can see how the fuel and air is distributing as a whole and that one cylinder isn't seeing a drastically different condition than the other.
Now I agree a 3k custom intake manifold that takes 3-6 months to get isn't for everyone. Once you break that 9.5-9.0 barrier though and cross over the 900-1000rwhp mark which you are close too I know, you have less room for error when it comes to airflow distribution on these 25-50k motors. It makes the 3k manifold well worth it.
Phil when you say Tom, you mean Tom Kempf right? Has he got the high CR pistons in now that he is going to run M1 with?
Old Jun 26, 2011 | 06:07 PM
  #37
7 Second Club
Yes, the other manifold is going on kempfs car. I dont care if your making 700 or 3700, if your on the edge of the limits of the combo, small changes in the airflow distribution can have catastrophic effects.
Old Jun 26, 2011 | 08:47 PM
  #38
The Alchemist's Avatar
UNDER PRESSURE MOD
Any idea if the intake that Marcella and Shawn were working on made any progress. It was supposed to be a cast peice I thought, and was a 2-peice intake split down the middle, it almost looked like the Edelbrock Proflo, just lower profile that seemed to taper in the rear.
Shawn posted about it a few months ago and said it should be available early summer and was wondering at first if this was the intake.
Old Jun 26, 2011 | 09:19 PM
  #39
I was just reading in another thread you posted in telling a guy that his elbow and carb intake was going to grenade his motor by running the front cylinders rich and the rears lean because of air distribution with high boost. I wasn't aware of this until I read your posts. I find a lot of info very valuable in the F/I section from you, josh at ky, fireball, MM and so on. I don't know why some people won't take it from people who have obviously been there and done that more times than they can or would like to count.
Old Jun 26, 2011 | 09:47 PM
  #40
SpeeedbumpS's Avatar
OMG, that is amazing! Great job.
