9.2 compression and ? Boost
Old Jun 29, 2011 | 12:16 AM
buick_lsx's Avatar
Default 9.2 compression and ? Boost
Been running 9 lbs on the stock motor with 10-1 compression...the new forged motor will be 9.2-1 compression...
How much more boost should that allow me to run on pump gas?
Old Jun 29, 2011 | 12:22 AM
kmracer's Avatar
intercooler? 91 or 93? what turbo/supercharger?
Old Jun 29, 2011 | 12:39 AM
buick_lsx's Avatar
93 octane, a/w intercooler, 75mm turbo
Old Jun 29, 2011 | 01:02 AM
kmracer's Avatar
playing it safe? 12-13. i woudlnt play with timing either.
if you wanna roll the dice you can probably do a couple lbs more. are you planning on hitting the dyno again?
Old Jun 29, 2011 | 01:41 AM
buick_lsx's Avatar
Yea, it'll be tuned on the dyno then track. Just trying to get an idea...13lbs would get me 700hp on pump and I'd be happy with that
Old Jun 29, 2011 | 01:43 AM
buick_lsx's Avatar
And yea, the timing won't change on pump gas. 609 to the wheels right now with just 15 degrees
Old Jun 29, 2011 | 01:48 AM
kmracer's Avatar
good luck! 15* should be very safe, even at 13.
Old Jun 29, 2011 | 02:07 AM
buick_lsx's Avatar
I'm sure race gas will see more timing. Might add meth for even more boost on pump but that would prob just get me in trouble lol
Old Jun 29, 2011 | 02:27 AM
kmracer's Avatar
exactly. i personally would rather tune on the dyno, get the torque/timing combo (mbt) along with a comforable boost level, and turn it down for pump. i wasnt sure if you were planning on running race gas or not.
are you tuning yourself?
Old Jun 29, 2011 | 02:56 AM
buick_lsx's Avatar
It'll be tuned on pump, that'll be close to 700rwhp and then race gas will max the turbo out
Old Jun 29, 2011 | 02:57 AM
buick_lsx's Avatar
Race gas might be for just 1 or 2 races a year plus dyno days lol
Old Jun 29, 2011 | 03:17 AM
kmracer's Avatar
cool cool. have fun mang.
Old Jun 29, 2011 | 09:35 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
what heads and intake manifold? 15psi on stock restrictive heads is a LOT different than 15psi on nice flowing aftermarket heads. What size engine? Takes a lot more air to feed a 427 than a 347. This is why you need to look at total power rather than total boost.
Old Jun 29, 2011 | 10:24 AM
buick_lsx's Avatar
This is on a 364-370 motor with stock 317's...when it gets forged the heads will be ported though. And edelbrock pro flo intake.
Old Jun 29, 2011 | 06:05 PM
yessir's Avatar
my stock lq9 see's 14 psi on pump with no meth, id imagine u could run more thah that on your setup
Old Jun 29, 2011 | 08:46 PM
robbyredneck's Avatar
what timing?
Old Jun 29, 2011 | 10:50 PM
kmracer's Avatar
great point, i should have asked, although 12-13 is a very safe number for almost anything with a 75mm turbo and an A2W.
Old Jun 30, 2011 | 04:33 AM
yessir's Avatar
not exacly sure, 13 or 14 i belive, lol was so happy with peak numbers i forgot to ask the tuner
Old Jun 30, 2011 | 05:24 AM
buick_lsx's Avatar
So what did it make with 13-14 lbs? And why dyno
