How'd you bend your PS lines to clear turbo plumbing
Looks like I will have to reshape my power steering lines a bit to clear my turbo plumbing. I couple of the bends are more than I feel comfortable doing "by hand" (literally with my hands) for fear of kinking or breaking them.
Any ideas? Fuel line tool or something?
for the non pressurized one i just cut the original hose off at the bottom on the hard line and just ran my own 3/8" hose around the idler pulley bracket. for the pressure side i did a little bending with it bolted on i think maybe even turned it a little. i dont have the down pipe going through there yet tho just a flipped exhaust manifold.
I bent my pressure hose by hand and routed it behind the alt idler bracket. I screwed up the return fitting so used the fitting feom az to route to my own p.s. cooler. Idk if the pressure side is too close to the crank hub but it should be running this weekend
