Signs of a bad Procharger?
#41
My car recently dropped on boost. Turned out to be a split silicon hose that opened up under boost. Couldn't tell unless the car was under pressure.
I also had an issue in the very beginning (2004) with my car collapsing inlet filters and inlet piping while under boost. Took me forever to find.
FWIW, I've seen a couple damaged superchargers on several track cars (no filter, sucked somthing in) and even with a badly beaten up impeller they still make boost.
#43
LS1Tech Sponsor
PVC caps will work, you should be able to come up with something at a hardware store pretty easily. You just have to be able to drill and tap it for the valve. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#45
Finally have an update. However it ended up not solving my issue. After a discussion with Procharger we decided it would be a good idea to just send in the blower. Unfortunately everything appears to be fine with the unit. Looks like I'll be doing that leak down test.
#47
#51
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#52
Procharger will not sell you replacement parts :-( I purchased ally mine frome superchargerrebuilds.com It's not extremely difficulty to do a rebuild but you really need to do your homework. I did mine over the winter I'm not going to lie and say I didn't f up a few times. It's a learning experience. But once you've successfully done it once it's a cake walk.
If it comes down to it I will figure it out, and make an instructional video. As long as it comes apart in a way other than shattered into a million ******* pieces I can put it back together most likely. 1600 dollars is enough to make me wanna try. If not...patch it up and send it to them.
#53
