Wiring a hi/low boost circuit?
Thanks!
and noticed my turbo spooled quicker and boost was a little more consistent. I know this is not what you asked but thought I'd pass along the info
Thanks!
My setup works great, no boost spikes, superfast spool. It is set at 9 psi. I can get full boost even with part throttle by 3000 rpm. Before the boost controller I would not have full boost (5.5 psi) until redline due to the high altitude here. Infact, it works to good no traction in first, second or the two/three shift even at a low of 40 % or so throttle.
Gary
Thanks!
Sounds like you have all the parts to do it. You could use a timer to switch between your different boost levels. You would need 2 solenoids for this, but it sounds like you have it all. You could start the timer off a button. This would give you xxpsi off the line. A few seconds later, the timer closes the first valve and then opens the second, giving you more boost.
Make sense?
Gary
this sounds very interesting.
I am a little curious how this will work
thanks
ed
Gary
Gary
I haven't had to change PCM programming for different boost levels. Once the power enrichment tables were set the MAF seems to do a good job of compensating for increased airflow. I pull 12 degrees of timing where I make peak torque and 10 degrees higher up the RPM range. Am I missing something? Just curious because I'm still tuning this thing and learning as I go. Haven't broken anything since the forged pistons were installed :-)
Thanks,
My 2 cents - flipping a switch for 2 boost levels sounds cool but is'nt worth the effort = choose one boost level and tune for it.
Let us know how it goes.
Just my own $.02.
Gary
Gary-
I didn't see a PM. Not sure what happened. I get what you are describing, though. That is what I will try once I pick up one more solenoid valve. Thanks!
Yeah PE does not need to change much but timing usually does. But of course I am running on 91 octane at 9 psi, with actual gas may not be an isssue. I sent you info for a back pressure regulator from mcmaster carr that will work as a relief valve. It has a **** to adjust boost, very sensitive. One turn is like .5 psi. I have one of these but have not tried in on the car. It leak tight until the boost set point. Check valve anything with .3 psi or less cracking and good seal off under pressure. I have not tried a vacuum relief valve, but they should work as well.
Gary
