AES 410c.i. LSX & KY-Turbo
#64
I spoke with Josh over the weekend. So the car is going in the shop today! All the modification will be made to the car. Then will go to paint. Then it's game on, on getting everything done and installed.
#66
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Call me tomorrow. Me and Craig have talked about going bigger.
#71
Plugging away on getting the car prepped for the paint shop. Alot of under hood work going on befre the car heads out. We are changing alot up in the front end of the car. This is not a quick turn around build. Nearly every aspect of the car is getting some type of Modification.
#73
I sure do hope so. I would like to sell the turbo I have and move up to a 91mm turbo or so. I cant help but to worry that I got the wrong turbo for the job. This car will be seeing 70% street time and the rest at the track. If I can sell it good and if not well we will just have to see what that Garret T6 GT47-88 will do.
#75
#79
We have a customers car running 7.60 with 410ci and 25psi using PT106. No problem spooling it with 3 step, CO2, and the right converter. It takes a few track visits to dial it in.
http://www.youtube.com/watch?v=VgSTg0f48kc
#80
I wouldn't mind a 47-88 for hyd roller street driven setup with 410.
