need help with pushing water
Old Jul 18, 2011 | 01:23 PM
  #41
6point7s14's Avatar
Back two cylinders.... Edit ^^
Old Jul 18, 2011 | 01:38 PM
  #42
Rickys S/C Z28's Avatar
Originally Posted by Heintz Racing
Brek,
When we tuned your car, with you wanting to push it as hard as you did on pump gas, it was tuned on straight M1 methanol. No water. If you have added water to it, it has surely leaned the car out and is probably detonating at that boost level. Double check to make sure the heads are flat also when you put it back together. Give me a shout if you have any questions.
Zach
ding ding ding we have a winner
Old Jul 18, 2011 | 03:01 PM
  #43
Nitroused383's Avatar
Originally Posted by Nitroused383
Probably detonation with that much boost on pump gas and water meth.
Originally Posted by NicD
This would be my guess
Hmmmm ??
Old Jul 19, 2011 | 07:45 PM
  #44
02anti_vnm's Avatar
Brek,
Zach
Thanks zach I had been under the impresion we tuned it on water meth to help with IATs but now that that's cleared up ill get full meth in it right away!
Originally Posted by 6point7s14
Since its the back cylinders, I am wondering if u have your back to steam ports blocked off.... If so I would start by gettin those back to functional
When you say steam ports your talking about the cross over pipe on the front of the heads and the solid block on the back corners of each head correct? What do I need to do there get a front crossover and put it on the back also? Some how T it in?
Old Jul 19, 2011 | 08:13 PM
  #45
6point7s14's Avatar
i know that trucks use a set that covers all 4 spots on the front and back... u might could T in another one like u have
Old Jul 19, 2011 | 11:45 PM
  #46
obZidian's Avatar
Looks like we have a winner!
Old Jul 20, 2011 | 07:40 AM
  #47
JHR Performance's Avatar
Closed ex-Sponsor Account
Brek,
Straight methanol will greater cool IATs than a water/meth mix.
Zach
Old Jul 20, 2011 | 10:40 PM
  #48
Nick Williams's Avatar
http://s41657.storefront-solutions.c...l.aspx?ID=3289
Should work for the coolant crossover
Nick
