turbo cam size
Old Jul 17, 2011 | 06:31 PM
powershiftingls1's Avatar
Default turbo cam size
After searching online for hours and calling performance stores here in vancouver bc i have no luck. Anyway i'm in the process of twin turbo' my 98 ls1 f body (got two turbos next to nothing) Engine is 100% stock. I plan to run 6-7 pounds of boost. Today i was taking the timing cover off to run the return fittings and my timing chain is slack as hell. I was going to change it and now i wanna put a cam. My goal is to hit 500ish rwhp. With that said i plan to put a 255 lph pump, fast/holley intake #42 injectors and meth injection to keep the temps down. Dont wanna go as far as putting heads. What do u guys recommend? im leaning toward an off the shelf cam so theres no hassle. Thx in advance guys!
Old Jul 17, 2011 | 06:38 PM
JRENIGAR's Avatar
Lingenfelter gt-2-3 is runnin its *** off in the 5.3 turbo s-10 in this forum.
Old Jul 17, 2011 | 06:55 PM
My friend has that gt2-3 in his T/A and it sounds almost exactly like the stock one at idle. I kinda want something that jumps a bit at idle
Old Jul 17, 2011 | 07:48 PM
Nitroused383's Avatar
I've done a ton of research and I've kinda concluded with most street setups the cam choice is not super critical. Pick a cam based on your needs, driveability, idle sound etc. There are benefits to running a custom specced turbo cam for race applications where you are not limited by the turbo. When you are trying to push 1000-2500 hp with a huge turbo and spooling the thing quick enough is your main concern than you will have a dedicated engine built around your setup.
Most street setups don't have a problem spooling properly sized turbo(s) with the cubes a v8 LS motor has.
The speedinc TU1 is proven 225/225 113 http://www.speedinc.com/manu.cfm
Here is another great off the shelf comp cam 227/224 115
http://speed-eng.com/store/comp-lsr-...a-p-10266.html
Old Jul 17, 2011 | 08:03 PM
old motorhead's Avatar
Twin turbos deserve a cam built for the job. Get Pat G. to spec you one. It won't cost any more than an off the shelf cam and you'll like it a whole lot more.
Old Jul 17, 2011 | 09:51 PM
Fbodyjunkie06's Avatar
Here is another great off the shelf comp cam 227/224 115http://speed-eng.com/store/comp-lsr-...a-p-10266.html
The cam in bold is the one I run only on a 114 it's a awesome cam enough idle to know it is cam'd and screams at WOT up to 6700 easily. The Speed Inc cam is an awesome proven cam also.
Old Jul 17, 2011 | 10:47 PM
hitmanws6's Avatar
Im going to have the Brutespeed cam in my 5.3 (232/240 .595/.608 115), my friend has an MS3 in a 113 in his 4.8 and loves it.
Old Jul 17, 2011 | 11:02 PM
turbofreek's Avatar
Ivebeen trying to find who has a bunch of different turbo grind cams on their site listed. I wanted one they listed with a mid 500 lift area with lopey idle, but can't find them since loosing my bookmarks. Any ideas guys?
Old Jul 17, 2011 | 11:22 PM
hitmanws6's Avatar
Speed inc or virginia speed
Old Jul 19, 2011 | 03:58 PM
chance575's Avatar
I have same cam too, I like it and it runs good.
