steam tube adapters
Old Jul 21, 2011 | 07:25 AM
sparkwirez06's Avatar
Default steam tube adapters
I have these steam tube adapters. I was going to drill and tap the heads for 1/8th" npt lines, and I found these, bought them a few years ago and can't remember where, the orfice is a little over !/8th" will these flow enough coolant to cool my turbos? I have my heads installed and I'm a little nervous about drilling and tapping them while there on the truck. thanks
Old Jul 21, 2011 | 07:35 AM
Reckless's Avatar
Super Moderator
Maybe you got them from us? Not sure about the turbo question though. Drilling and tapping the heads would be better off the engine.
Old Jul 21, 2011 | 10:26 AM
Default turbo coolant lies
I drilled and tapped them,took my time used a lot of lube,used constant suction and went slow.
Old Jul 21, 2011 | 11:16 AM
SPRAYED 01's Avatar
Why doesn't any one just use the factory steam tubes that were on the earlier f body ls1 cars?
Old Jul 21, 2011 | 11:25 AM
XtremeDime's Avatar
Because everyone wants to go through all the trouble of tapping their heads, or tapping the small aluminum blocks instead of trimming a little off the underside of their manifold
Old Jul 21, 2011 | 04:37 PM
SPRAYED 01's Avatar
That's what I thought. I trimmed under my intake and bent the tube alittle and its good to go.
Old Jul 21, 2011 | 05:25 PM
Reckless's Avatar
Super Moderator
The early style vent tubes will not fit under certain intakes due to the intake floor being lowered. Anyhow, I can't remember all the LS1 style vent tubes I modified to delete the rear connections when the LS6 intakes came out
Old Jul 21, 2011 | 09:36 PM
What's that got to do with cooling my turbos?
Old Jul 21, 2011 | 11:06 PM
slownova73's Avatar
this could end up with some good info. im in for some learning.
Old Jul 22, 2011 | 09:12 AM
Reckless's Avatar
Super Moderator
Sorry, I was answering Sprayed's question
Old Jul 22, 2011 | 06:43 PM
Project GatTagO's Avatar
Wegner makes those adapters.
Andrew
Old Jul 22, 2011 | 08:05 PM
JAX04's Avatar
Off topic, But i was absolutley thrilled to find out when i picked up my 4.8litre motor that it had the full steam tubes, front to back, i was happy as could be
Now just need an intake that will fit over them...
Anyway i believe gattagO is correct.
Old Jul 22, 2011 | 08:51 PM
http://www.kurturbanperformance.com/ This guy made mine,they can accept a 1/8th npt fitting. I just don't think the pin hole would flow enough coolant for the turbos. thanks
Old Jul 22, 2011 | 09:42 PM
XtremeDime's Avatar
The steam vents wont flow enough to cool your turbos.
Old Jul 22, 2011 | 10:10 PM
used by a builder with a twin turbo lsx typhoon, like mine!!!!
Old Jul 23, 2011 | 11:47 PM
NBM-LS1's Avatar
I used an LS3 front crossover on the rear and then ties it into the front one. $30 and some change from GM.
