which boost piston??
Old Jul 26, 2011 | 03:30 PM
camaro383's Avatar
Default which boost piston??
Im rebuilding my.motor and after cleaning the cylinders my piston clearance is to big now, what are some good pistons and should i waste money on a stroker crank? Or stick with the stock crank
Old Jul 26, 2011 | 03:35 PM
LS1RedZ's Avatar
I would get some Wiseco Turbo Duty pistons and keep your stock crank. Throw some boost at it!
Old Jul 26, 2011 | 03:43 PM
camaro383's Avatar
Ya i am kinda between cp and weisco, just not sure which one, ill prob get weisco cause i have them and they came out looking like new and i think weisco's come coated already
Old Jul 26, 2011 | 10:35 PM
dudeman's Avatar
i use wiseco and a stock crank. i just put a 100 shot on my car also. everything seems to be doing just fine.
Old Jul 27, 2011 | 04:37 AM
ausls1's Avatar
what size Wiseco? i'm doing a boost setup on a 346 with stock crank and a set of Callies rods with ARP2000 rod bolts but can't find a wiseco piston to suit, i see 3.903" bore then jumps straight to a 4.000" bore, but i need a 3.905" bore, does anyone know if i can get this from wiseco in a -11 dish? or there abouts for 9-9.5 CR on 241 casting heads with 64cc.
Old Jul 27, 2011 | 03:56 PM
killernoodle's Avatar
You can get diamonds in 3.905, they are comparable to the weiscos. I have a set in -8.6cc that I have yet to install but they sure look like quality pieces.
Old Jul 27, 2011 | 10:53 PM
ausls1's Avatar
Sweet might give them a try and see what there like, did u have to get upgraded rings for it or they come with good rings already for boost applications?
Old Jul 28, 2011 | 10:08 AM
bravolistick's Avatar
-13cc Diamonds here, with stock crank, number in sig, runs great
Old Jul 29, 2011 | 07:59 AM
ausls1's Avatar
holy crap, i'd be rapt to be making that power, or close to it, what comp ratio does yours have and heads done?
i know yours id a 6.0 so different bore size but still a good indication.
