Full Boost....when?
Old Jul 30, 2011 | 11:15 PM
Estes's Avatar
Default Full Boost....when?
When should I be seeing full boost on a turbo set up. I have it set to 6psi and just wondering if you only see 6psi at high rpms. I see boost quickly, and it builds up to 6 and stops, but it just takes a minute. Small leak possibly or is this normal?
Old Jul 30, 2011 | 11:33 PM
SippiSpeedhawk's Avatar
Some details on your setup would be useful.
Old Jul 30, 2011 | 11:40 PM
Estes's Avatar
Sorry. One 72mm Turbo. Unsure of A/R, Tial Wastegate/6psi. 6.2liter LS3. Upgraded fuel system able to support proposed 750hp. No cats, or muflers.
Old Jul 31, 2011 | 12:03 AM
Sluggish's Avatar
You should be seening full boost at around at lease 3000 rpm with that motor and small turbo.
Old Jul 31, 2011 | 12:16 AM
Fbodyjunkie06's Avatar
This, your drive pressure will be a lot higher with that turbo than a LS1 would which will help build boost very quickly but it will also fall off faster too. Does it jump to 6 then flatten out around 4-5 psi?
Old Jul 31, 2011 | 12:20 AM
Estes's Avatar
No, it gets to about 4 real quick and then slowly builds up to 6. I can't remember exactly what rpm it gets to 6 at. Maybe 4500 or later.
Old Jul 31, 2011 | 12:33 AM
If you suspect a boost leak they make a smoke machine that pumps through the intake tract and can identify a vacuum or boost leak.
Edit added: My car will jump to 9psi really quick then at around 4300-4400 it hits 11-12.
Old Jul 31, 2011 | 01:06 AM
Estes's Avatar
Thanks, judging by your quick 9 and then up to 11-12 things on my end are normal. Sorry, I'm new to boost. Learning quickly on this sight though. Thanks again.
