98camarod's twin turbo build
Old Jul 31, 2011 | 04:55 PM
98Camarod's Avatar
Default 98camarod's twin turbo build
I have found some new motivation to start and finish this build. I had to accelerate a little in the G8 GT that we have and my daughter was in the back seat. The only thing I heard was her screaming, "GO! GO! GO! GO!" I'm sure the Camaro will be a bit much, but that GT is SLOW!
-forged 347 with some worked over 317 heads with about 9:1
-kytp twin tc78 truck manifold kit
-meth
-th400 with brake
-ford 9" with 3.25's
-dual walbro's, -8 feed, -6 return, aeromotive boost ref reg
-80lb SD's
I sold my ls6 intake and I'm looking to get a fast 90 or 92 setup. I'm working on the fuse box relocation now. I've got the a/c delete panel made up and mounted. I've cut the unnecessary metal out of the engine bay and removed the stock fuel lines.
Old Jul 31, 2011 | 05:19 PM
MUSTANGBRKR02's Avatar
I relocated my two fuse boxes on my camaro to inside the car where the passenger airbag used to be. It would be a better place to keep water from getting on them. If you would like I can provide pics.
Looks good so far!
Old Jul 31, 2011 | 05:26 PM
98Camarod's Avatar
Looks good so far!
I'm not worried about that, thanks though. It will be garaged once the motor and trans get in there.
I bought the primer yesterday to prime the engine bay. I'll paint it and then throw the motor and trans back in there.
Old Jul 31, 2011 | 05:34 PM
Speed Density's Avatar
hashtagBMW
Looks good, that relocation has promise.
Old Jul 31, 2011 | 05:45 PM
Sluggish's Avatar
Beast mode will soon be engaged. Your braver then me, I hate wiring.
Old Jul 31, 2011 | 06:41 PM
1fast bird's Avatar
Can't wait to see what the 76's do in the 347. Good luck man!
I hope you are changing the charge pipes. Where the fuse boxes were relocated to, will be in the way for sure. You will have a 2.5" and a 3" pipe going through there.
Edit: It may work but it will be tight.
Old Jul 31, 2011 | 09:30 PM
98Camarod's Avatar
I didn't realize the 2.5" went through there as well. I seen that the 3" goes right next to the frame rail, so we'll see. If I have to, I'll cut more **** out so I don't have to mess with the wiring again.
I've probably got a good solid 4 hours of soldering in it and I'm at 27/40 wires.
Old Jul 31, 2011 | 09:31 PM
98Camarod's Avatar
I do to. I hope I don't have any problems once it's done. I'll be screwed.
Old Jul 31, 2011 | 09:33 PM
98Camarod's Avatar
I'll get an overview shot once it's done there. It should be wide open where I cut away. So I don't see why they wouldn't fit.
Old Aug 1, 2011 | 07:11 AM
1fast bird's Avatar
It wouldn't hurt to mock it all up to make sure it fits before getting it painted. It is a very tight fit.
Old Aug 1, 2011 | 01:13 PM
ttranssam's Avatar
Dude, I'm not evin going to lie to you...if you seen my build you would **** yourself!!! So far we pree much going the same direction, just for me I'm doing tubular headers...f*ing scary
Old Aug 1, 2011 | 02:08 PM
CarsandWomen's Avatar
lookin good!
Old Aug 1, 2011 | 04:32 PM
98Camarod's Avatar
I would have gone with the headers, but I don't have the money for those right now.
Originally Posted by CarsandWomen
lookin good!
Thanks!
I got the extensions finished up today. I've got to find some wire loom to go around it and some hold downs as well. I need to find where to cut on the passenger side so I can have that done already.
I routed the fuel lines up the engine bay. I'll probably have to adjust them once the down pipes are routed. I also got some filler in to cover up some holes.
Old Aug 1, 2011 | 05:04 PM
I would temp connect the wires to make sure that everything works before soldering and heatshrinking everything.
Old Aug 3, 2011 | 05:02 PM
98Camarod's Avatar
Tiny bit of progress but damnit it took a long time doing it by myself:
Old Aug 3, 2011 | 05:08 PM
95batmobile's Avatar
jelly
Old Aug 3, 2011 | 05:54 PM
Aluminum foil also works for covering stuff for paint and cheaper.
Looking good!
Old Aug 3, 2011 | 06:12 PM
DopeFedZ's Avatar
Might be better just to drop the front before you spray it. I taped the crap out of mine and still had over spray on my suspension.
Old Aug 3, 2011 | 07:12 PM
98Camarod's Avatar
I'm going to drop it and roll it into the garage. I taped it mainly to avoid scraping it when I was installing it. I used old towels as well and still got a couple scrapes on there.
Old Aug 18, 2011 | 04:24 PM
98Camarod's Avatar
Did some more work. I've never welded steel, so that was interesting. I've never sprayed anything aside from using a rattle can, so that was interesting as well. The whole house smells like paint, it's awesome hahaha. I'm going to get the paint and clear tomorrow and spray it this weekend. Then I'll put the ol' engine and trans back in this bitch and get it going!
