98camarod's twin turbo build
#41
Got a little bit done today> I mounted the intercooler up, hooked the computer up and found out that I need a different knock sensor hookup, mounted the injectors and fuel rails, hooked up the manifolds and the hot parts to the turbos. I have to mark and notch to get them to fit. I didn't get any pics of the computer and wiring harness stuff though.
![](http://i88.photobucket.com/albums/k199/Therod0120/08272011006.jpg)
![](http://i88.photobucket.com/albums/k199/Therod0120/08272011005.jpg)
![](http://i88.photobucket.com/albums/k199/Therod0120/08272011003-1.jpg)
![](http://i88.photobucket.com/albums/k199/Therod0120/08272011004.jpg)
#48
Super Moderator
Brings back old memories, but I didn't put a turbo on mine! But I did do a lot of the same type of work (circa 2003). Looks like it will be lots of fun!
https://ls1tech.com/raceinfo/retro.html
#50
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#54
I got the notches cut, I have to weld in the pipe in place. I mocked up the drain lines and got all the other piping mocked up with the intercooler. It all has to come back apart so I can weld in the pipe though. It makes it look alot closer than I really am hahaha. I'm waiting on my knock sensor harness and aarons intake elbow then I can button up the top end.
![](http://i88.photobucket.com/albums/k199/Therod0120/camaroTTbuild002.jpg)
#55
I got a little bit of welding done. I need to put the bottom on the inside one and I'll be done with the drivers side. I should be able to do the passengers side tonight. After the welding is done, I'm going to tape off the areas and use undercoating to cover up the nastiness.
This is my first time welding steel
Nas-T welds:
![](http://i88.photobucket.com/albums/k199/Therod0120/camaro003-1.jpg)
![](http://i88.photobucket.com/albums/k199/Therod0120/camaro004-1.jpg)
Nas-T welds:
![](http://i88.photobucket.com/albums/k199/Therod0120/camaro005.jpg)
#56
I finished the welding and it looks horrible. I'm done with it though. I'm going to tape off around it and spray it with undercoating. My new rack and pinion got here today as well as my outer tie rods and knock sensor harness. So, I see it being a productive weekend
![](http://i88.photobucket.com/albums/k199/Therod0120/WELDS003.jpg)
![](http://i88.photobucket.com/albums/k199/Therod0120/WELDS002.jpg)
