Cog dyno/boost results.........
Hey, Ya I would run the 28 teeth on the blower cog. I believe I have a 30 right now I could sell you if you want... Anyone want a 30 tooth cog blower pulley??? I'll need to check to see if it's 30. Lee charges me 80 bucks for a blower cog pulley. I'll sell it 50 bucks shipped.
Clint
i know i'm going off on a tangent, but i had a gap between my 8 rib and the pulley too, but i put a early corvette ring gear spacer between them ( fit perfectly after a bit of machining).
does anyone think that having that gap causes unneeded stress on the crank bolt? or maybe causes some harmonics that cause the belts to fall off ( i guess it's not as bad when on a cog belt)?
hugger: thanks for the info.
I installed the COGS myself, and so far after 350miles or so I haven't had any major wearing issues and no walking off issues, so I know I'm close, I just need to get better belt wrap....
Clint my blower pulley is 31 teeth right now so I don't think the 30 would really make a difference.......I'm still waiting to hear from Lee@ASP if he ever decides to respond...
I'll be going on the dyno in a few weeks.........hopefully sikora can take a look at it to see if we can make any "minor" adjustments before it goes to the shop.......
Bos glad to hear that yours are showing some good promise...I should have just left the belt on top of the tensioner
it was working good there. Now I have to cut this one off....30 bucks down the drain.J
I shoulda saved a lil bit more for the ATI dampner, but we are creatures of habit and I always do things the hard way
Cut the belt off today, time to order another one.
J
Kyle
Mark
Sounds like a killer project. So you only read 9 pages huh, There is another post of mine that went to 20+ pages of my personal hell with two sets of these things
With the ATI dampner you will be set. The crank cog won't spin like ours MIGHT under high loads due to how its held to the stock LS1 pulley.
If this thread is dead by the time you get to yours, post up I would like to know how things are going with that 408
Another area that might be a problem is with the knock sensors on our cars being so sensitive and how these cogs like to make some pretty good vibrations in the ol engine compartment. I will get some good logging done tomorrow. I will be watching how my KR is without the cog belt on. With it on I was picking up some serious KR from stopping or taking off at a light and between shifts. At WOT it wasn't as bad, though I was seeing a high of 4 deg KR which is probably due to my hypersensitive 98 knock sensors. Damn 98's
Glad to see you post up Mark, don't be a stranger....misery loves company....j/k...or am I?
J
I don't like the idea that it backed out like that especially w/the blue locktite on there, maybe red this time?
Any ideas guys? I hope this doesn't continue to be an issue, I can't spin the washers by hand behind the head of the bolt, so it probably didnt back out that far, I'm still pissed that it did.......
I don't have a flywheel holder, so I might just wait until I take it to sikoras and have it towed there........I don't think there is a way I can get it tight enough to drive by hand or is there?
I cut the belt off the car because I was panicking when I heard the noise and I didn't want to get caught on the road where I was didn't need any extra stress on it......I noticed on the belt that it is wearing more A LOT on one side, this could be a possible alingment issue.......
I just don't want that damn bolt coming back out in the future, especially with how often I drive the car around........
oh and i use a stock crank pulley too, but what i noticed that all of you ( i think) have dowels on your crank pulleys or cogs; mine has bolts. and i love them, the never sheared (sure they ate into the side of the pulley, but that shows you how strong they are). just thought i'd share.
Mark
I'm going to put the car up on the jack stands soon and try to hand tighten it now for driveability.......don't want to pay tow bills to drive it to where it needs to be.....
Tom, did you try messing around w/your setup yet?
If I get it tight by hand again, do you guys think it will be ok to drive for about 10-15 miles to sikoras? He said if the material isn't too hard hes going to tap it for bolts.....but I got to wait until after april 10th.....
I'll get this setup right eventually.......
Not yet, this third shift stuff after 20 years of second shift is kicking my butt. All I do is work and sleep, no time for the car at all.
Tom
