Cog dyno/boost results.........
Might be a step in the right direction, but how do I take this belt off now so I can add 2 more washers to the stand offs?
I might take it for a spin tomorrow, in the daylight just in case something decides to break off, like the s/c
I am serious this thing is that tight. Big NO NO for a cog belt.Bos do you have your crankshaft keyed? I do, but.....
The crank pulley moved, from the lack of a pin not holding it in place.
I would have just took off the crank pulley and replaced the pin with the extra one that came with the pin kit, but I sent the extra pin and the pin kit to Canada. I let Draco from the board borrow it.
So I am going to have to find another pin. Also another reason why I have to find out how to get the belt off lol.
I think I am going to use the other crank pinning kit, the one that goes from the face of the crank instead of the side.
I didn't want to put this in the post above, it was already to long. Just make sure that if your crank is pinned that the pin stays put.
J
Bos, no dice on the tensioner, when unbolted all it did was hit the idler that is now a hair away from it, I'm going to cut it off. The damn thing won't budge, I tried to "slide" it off the s/c cog and the crank cog with no luck
Man I am tired of this.
J
You were talking about possibly putting a lot of stress on that "weak" part of the bracket, but once the tensioner is bolted down, the stress will be taken off.....
We will get something worked out, I'm hoping to get into sikoras within the next few weeks, I'm done tinkering with it for now, going to put more miles on the trans and motor and wait.........
I really feel that taking out more material from the center of the bracket will make it weaker. Especially since I have no support from the s/c to the block, like the bracket you have. With the slot opened up more, and the bracket flexing from the s/c side toward the engine, the stress should crack/break the bracket. I don't know if that makes sense but I feel that the bracket draws some of its strength from the center.
I have the slot opened to just under the bottom of the standoff holes, so its pretty high.
Other than that I just don't see it working with the tensioner on top. I'd hate to say it. Maybe lee will do the right thing and make all of us smaller cogs or somehow convince gates to make us a belt or find one that is a lil longer to work with what we have.
At least one set is working good enough to put miles on it. My car use to be a daily driver before all this crap.
Who wants my cogs? 500 and they are yours.
J
Remember your setup was doing fine on the dyno, so get the new tranny in there, get the fuel worked out, throw it back on and see how it does.....
I'm thinking about having mine put on the dyno soon just to see how well the belt holds.....I am very suprised as to how the belt wears, pretty good.....
Me driving the car and bringing up the rpms slowly to 4000 will start to make the belt jump teeth, I don't know why it does it, but on some part throttle hits it grabs fine........
I think I will be rerouting the belt back on top of the tensioner for the time being. After I get a new one, cuz this one has to be cut.
I think the reason yours is doing this is because of the belt wrap issue we have running it on top of the tensioner. I haven't slow rolled it, just a nice quick acceleration into boost and it holds? I should try that to see if it skips.
I am kinda put out by all this, the car has basically sat from the beginning of Dec until now. All because of these stinkin cogs. I just want to be done with it...or at least working on something else besides the s/c.
J
Just a thought.
If I need to retune after that, so be it....
Kyle
Get some pulls with it and see how the belt holds up......
My 60's came in a while back....
I want to see how the car does for now, and when sikora is ready, I will take it to him so we can find a way to get some more belt wrap around that blower pulley, then if there is a need to retune do to more boost or something, then so be it...........
I'll find out tomorrow when and if I'm going to be able to get in soon
Kyle
I wish I could follow this route too, but my cam needs to be spun 6500+.
Dirty, Lee hasn't replied to any of my emails, I think he is done with me lol
J
Jeremy, I plan on doing a cam swap in the near future after I see what this setup can do.......
The motor now will be spun to 6400-6500, but we will find out where peak power will be on the dyno.......
I will run that idea by sikora when I talk to him.......
does your crank cog sit flush with the outside of the crank pulley? ( is there a gap between them?)
